Evo 9 5 speed transmission/clutch
Old Apr 29, 2025 | 12:56 PM
Adbraxx's Avatar
Good evening guys my car won’t go into gears after driving for a while I don’t understand why. I have a brand new atc clutch transmission fluid is topped off and I bleed the clutch. It’s hard to explain because you can shift perfectly fine until you can’t, no gears would go in and when it goes it feels like you forcing it. I appreciate your advice I’m looking forward to read your thoughts
Note: the car shifts well when on movement but it’s hard to shift when parked.
Old Apr 30, 2025 | 04:28 AM
blackline's Avatar
5 Year Member
Have you adjusting your clutch pedal?
Old Apr 30, 2025 | 06:53 AM
Adbraxx's Avatar
yes I did but it didn’t help
Old Apr 30, 2025 | 08:10 AM
ViciousLSD's Avatar
did you check the shifter cable + bracket. make sure its mounted correctly and no obstruction. I know my rerouted batt wiring gets pretty close
Old Apr 30, 2025 | 08:56 PM
Adbraxx's Avatar
I haven’t check the shifter cables that’s going to be the next thing.
The fluid level stays the same I don’t have any leaks but chat gpt suggested that the clutch master cylinder might have an internal leak and might not get the pressure necessary to shift.
Old May 1, 2025 | 12:09 PM
AWD96's Avatar
Never thought we would get to a point in the world where Evo owners are Chat GPTing their issues but here we are!
You can verify clutch movement by watching the fork outside of the vehicle while someone pushes the clutch or record it on your phone while you do it. The transmission mechanically either shifts or it doesn't, time and or heat isn't going to affect the function for the most part.
If there is moisture around the clutch master cylinder inside the vehicle that could be the issue
Old May 1, 2025 | 09:41 PM
Adbraxx's Avatar
Only when parked the car wont go into gear unless you rev it. no moisture inside the cabin. I had someone pump the clutch while I watched the slave cylinder move and I didn’t see anything strange they still couldn’t put it into gear I bleed the system a couple of times and even gravity bleed, nothing seems to work
meric
15
May 10, 2014 08:44 PM
MarkChamorro
Aug 5, 2012 02:08 PM
FroZenEvo666888
Aug 23, 2011 08:43 AM
gentlyharsh
South Region
Jan 18, 2009 09:40 AM
ballallday89
Oct 28, 2007 03:20 AM
