Best Tranny, Diff fluid combo.
Old Apr 22, 2004 | 10:27 AM
Trent@MVP's Avatar
All of our customer cars as well as our personal cars use Royal Purple. It's some of the best, if not the best, stuff out there.
Old Apr 22, 2004 | 11:34 AM
GOKOU's Avatar
So you can put 75/90 or MT90 in the tranny because a few people have use both. I thought it was MT 90.
Too many choice so I can't decide what fluids to use.
Old Apr 22, 2004 | 06:26 PM
Shahul X's Avatar
Syncromesh in the Tranny
Redline shockproof light in the TC
Redline 75w/90 w/4 oz of friction mod in the rear diff
-shahul
Old Apr 23, 2004 | 05:32 AM
GOKOU's Avatar
-shahul
How's the car running with these fluids and do you need the friction mode with 75/90?
Thanks
Old Apr 23, 2004 | 08:15 AM
Shahul X's Avatar
runs very well..... only needed the friction mod since I was using the 75w/90 NS (NS was the tuneable oil)....If I could have gotten the regular 75 w/90 I wouldnt have needed it....
-Shahul
Old Apr 23, 2004 | 08:26 AM
YEVOVIII's Avatar
HMMM
So u don't need the friction modifier in the TC do you? What is this NEO stuff some people are using? Never heard of it. Thanks fellas. Wish I could finer AMSOIL around DALLAS
DrEvo's Avatar
GOKOU - I am also researching on this. It looks like everyone seems to either go with Royal Purple or Redline.
Shahul - Can you elaborate more on the friction mod?
"Redline 75w/90 w/4 oz of friction mod in the rear diff"
Old Apr 23, 2004 | 08:31 AM
Bogie's Avatar
Synchro Shift in tranny
Red Line Shock Proof (heavy) in tc AND rear diff--2 oz (1/2 bottle) modifier in rear diff.
Old Apr 23, 2004 | 09:47 AM
jwtodd60's Avatar
Re: HMMM
http://www.neosyntheticoil.com/index_old.html
JW
Old Apr 23, 2004 | 12:42 PM
berkel's Avatar
NEO RHD in the center and rear and Redline MT-90 in the transaxle here as well. If NEO made a GL-4 for the transaxle, I would put it in there as well...
NEO rocks, but it's spendy. I also have it front and rear in my wife's WRX and it's great, esp with the Kartboy short shifter and bushing.
Take care,
FB
Old Apr 23, 2004 | 01:20 PM
Shahul X's Avatar
basically if you find 75w/90 your fine.... but if you get the 75 w/90 NS, then you need a bottle of friction modifyer....
If you can get Amsoil series 2000 75w/90 your fine....
this is for the Rear diff, use lightweight shockproof in the transfer case
-shahul
Old Apr 23, 2004 | 01:47 PM
DrEvo's Avatar
Thanks for the info Shahul.
Berkel - how does the car drive with Redline in the tranny?
Also where did you get your NEO fluids from?
I was doing some more searching around and I found this other thread which is kind of scaring me from putting anything else but stock fluid:
https://www.evolutionm.net/forums/sh...light=gear+oil
Old Apr 23, 2004 | 02:07 PM
Silencer's Avatar
Take care,
FB
NEO does, it's HD which is GL2-5 (RHD GL5-6). Read:
"NEO 75W-90 HD meets the requirements for GL-4 grade even where manufacturers discourage the use of a GL-5 product. It is recommended for front wheel drive transaxle use where GL-4 performance is specified."
I have this in my tran's and RHD in my diff's.
Old Apr 23, 2004 | 08:09 PM
berkel's Avatar
I'm happy with the Redline in the tranny. It's smoother and quieter (I had the decel noise, but it's gradually lessened).
I first changed at ~3k miles, then again at 15k. I'm at 16K now. Shifter feel also improved with the kartboy underhood bushings.
I got my NEO stuff from Bakerprecision:
http://www.bakerprecision.com/neocirc.htm
Silencer,
Thanks for the info on the compatible NEO for transaxle, I may try that next time.
Take care,
FB
Old Apr 24, 2004 | 12:44 AM
cognisa's Avatar
where is the drain plug on the tranny and the filler hole.and how many quarts it takes?
