View Poll Results: Are you using an octane booster?
No, I have not tried it.
67
51.94%
I have tried the off the shelf stuff at the auto store.
33
25.58%
I use Xylene/Toulene
29
22.48%
Voters: 129. You may not vote on this poll
Octane Boosters
Old May 28, 2004 | 12:54 PM
NoVetteinOK's Avatar
I used the Outlaw "sh.t" and it caused one of the cynliders to misfire due to a screwed up plug. Don't waste the money. Buy a aftermarket computer and map for race fuel.
Old May 28, 2004 | 01:41 PM
nothere's Avatar
I am in the middle of a water injection install. Once in, it should replicate 100 octane from 91 or 92 pump gas. a bit of a pickle getting everything installed without making a mess of it.
Old May 29, 2004 | 06:48 AM
Evo442's Avatar
Originally Posted by evo542
can you use xylene/toulene combined, or use just one at the time
You can use both or either. doesnt matter. both are just hydrocarbons.
Old Jun 1, 2004 | 02:05 PM
Nellie's Avatar
Hey, keep us posted. I'm interested in a water injection kit. What manufacturer did you go with and what are the problems with the install?
- Nellie
Old Jun 1, 2004 | 04:33 PM
Evo442's Avatar
Please keep us posted! I'm very interested in WI also!
Old Jun 1, 2004 | 06:28 PM
nothere's Avatar
I'll post my experience with the WI install in another thread in the next few days.
Old Jun 1, 2004 | 09:27 PM
Nellie's Avatar
Thanks Nothere.
I've read and followed accounts of Aquamist systems on Saab turbo's so I'm looking forward to hearing your thoughts.
Nellie
Old Jun 8, 2004 | 07:40 AM
dwx's Avatar
dwx
Water injection is a proven way to protect against detonation, I've run it on my WRX for over a year now with good results. However don't use it to replicate the gains you would get from using proper fuel. There are race teams out there (mainly WRC) that do use water injection but it's to keep EGT temps down and is used a safeguard. WI != race gas.
I've used the Torco Accelerator stuff before and it works wonders, but it likely contains MMT or something similar. You can get a case (6 cans) of Torco for like $11/can. If you mix 32oz of that stuff into 10 gallons of 92/93 octane it raises it to somewhere around 104 octane. Half a can (16 oz) to 10 gal. will get you to around 99 octane.
Currently there is a place not too far away (about an hour) that sells 100 unl for around $2.70/gal so I just go down there with 5-6 gas cans and fill up every so often.
Old Jun 8, 2004 | 08:05 AM
number 8's Avatar
I've been using Torco Accelerator. But, I recently noticed that it does leave a pink dust on the spark plugs.
Old Jun 8, 2004 | 09:27 AM
djh's Avatar
djh
That would be MMT then. Long ago ferrocene, a similar compound containing iron, was used as a knock inhibitor. It worked but formed iron oxides (jeweler's rouge) during combustion -- manganese oxides aren't quite as abrasive, I think. There are "issues" concerning the effect of MMT on O2 sensors and catalytic converters (Mitsubishi doesn't approve, of course). You make the call!
Dave
Old Jul 16, 2004 | 06:42 PM
RalliArtEvoVIII's Avatar
you guys buy these boosters and put it in every tank u fill up on? isnt that a lot of money at the end. I wanna try this, buy I dont think I wanna be spending all this money on daily driving
Old Jul 16, 2004 | 07:03 PM
EvoTio's Avatar
nothere, any luck with your water injection set-up? I did a Aquamist set-up on my Talon AWD and it worked pretty well. I am going to pull it out of my Talon and install it on my EVO within the next couple of months. I'll post my results when I get it finished.
Old Jul 16, 2004 | 09:37 PM
nothere's Avatar
evotio,
yeah everything is up and running. just waiting on my ecu to come in so I can adjust fuel.
if you have any questions about where to mount it send me a private message
Old Jul 16, 2004 | 09:56 PM
gofaster87's Avatar
Toluene has worked great for me but I have since switched to just using 101 octane gas. I was mixing 2 gallons of Toluene with 12 gallons of gas. Very noticeable difference.
Old Jul 24, 2004 | 01:30 AM
Sentinal's Avatar
Thats an expensive way to drive... I put about 100 miles a day on my car so good ol' 92 octane from the pump is fine for me
