high clutch pedal engagment
Old Apr 28, 2004 | 10:17 AM
rt turbo's Avatar
Question high clutch pedal engagment
i have a spec stage 3 clutch, restrictor removed and a braided line. the engagement is crisp and clean, but the engagment point is almost all the way off the floor for the clutch pedal. i blead every bit of air out of the lines, but it will not engage any lower. what can i do to make it engage either lower to the floor or engage more in the middle of the pedal travel field?
p.s. i found adjustments on the underside of the clutch pedal arm inside the cabin, but that doesnt help with the engagment point along the travel of the pedal. as is, the clutch engages 4 inches from the floor with a total of a 5 inch travel for the pedal.
Old Apr 28, 2004 | 10:33 AM
UFO's Avatar
UFO
Adjusting the clutch rod in/out sets the engagement point for the pedal. It is not unusual for Evos to engage high in the pedal travel either. You might find that, by adjusting it too far, the clutch isn't properly disengaging though, so don't so that .
