should i buy downpipe or not....
Originally Posted by mifesto
hey hungbee112, how is the fitment of the Lancershop DP? is it pretty close to the oil pan? does it hit anything, rattles? any leaks?
Originally Posted by boomn29
Tell those guys to PM me then! I'm still looking the used route!
Who sells a 2.5" HF cat anyways?
Any dyno numbers.????? People say it is a great mod, but every dyno that I've seen that has tested the downpipe exclusively has negligible gains... There was an article posted by a tuner magazine that broke the gains down... I'll try to find it... I was less than impressed...
I would bet that a test pipe and catback make more power than a downpipe, highflow cat and catback...
Originally Posted by Hungbee112
I'll keep an eye out for you, but ultimate racing makes 2.5 high flow cats. You should check them out, I hear nothing but good things from them.
This is the only article that I've seen to test the downpipe on a dyno...
http://www.importtuner.com/tech/0312it_pplancer/
as i said email turbotrix they have it on there dyno sheet..... I saw it personally when i was down there... 21 whp just from the DP.... stock cat and stock catback......talk to mark or jeff
Grod is right ... We did have like 20whp gains from a dp.. Every evo is different.. but that was done back to back ..with an RMR dp. I do know that the stock cat is the biggest power robber in that car. A stock exhaust with a cat delete would be better off then a dp and cat back ..any day. Just an fyi... The car detonate soo easy with a stock cat and mods..
Mark
turbotrix
Mark
turbotrix
for xtang --> theres little point of installing JUST the 3 inch DP if the other bottleneck isnt freed up... thats why you see negligible gains during an exclusivly DP testing
