21 PSI 3rd and 4th gear
Old May 2, 2004 | 12:21 PM
batty's Avatar
Ok so i just noticed that in 3rd and 4th gear i peak at 21 psi. 1st and 2nd is 19. I checked all my connects etc... I removed the mutant hamster from inside of turbo.and it stills goes to 21 psi. I have a stock setup except for a catback. Any ideas?
Old May 2, 2004 | 12:32 PM
Fourdoor's Avatar
My idea is that you got lucky Or your boost gauge reads a bit higher than you are boosting in reality.
Keith
Old May 2, 2004 | 01:17 PM
evo542's Avatar
i think it's normal because that's why when on the dyno, they do 3rd gear runs, there's more engine load
Old May 2, 2004 | 01:26 PM
naucrx's Avatar
They normally do 4th gear pulls on the dyno, that's the gear that has the closest 1:1 gear ratio.
Old May 2, 2004 | 01:47 PM
weightless's Avatar
was it cold out and do you have a test pipe? 21 psi is not ridiculously high even for a stock car and it's safe because it's just a spike. Evo's do vary in boost and I would be happy if I were you.
Old May 3, 2004 | 10:35 AM
batty's Avatar
no test pipe and its been warm out. My gauge reads right also. Guess i should be happy.
Llew
Oct 14, 2015 03:14 PM
TheEvolutioner
Jan 21, 2008 10:16 AM
coolguycooz
Oct 31, 2006 01:08 PM
Jinu0808
Sep 15, 2003 02:59 PM
