Stupid Question
Old Sep 7, 2002 | 04:48 PM
Alan's Avatar
Stupid Question
Can the turbo be removed from a turbo car, to make it non turbo?
Old Sep 7, 2002 | 09:06 PM
GPTourer's Avatar
NA
I'm not a qualified technician, but I'll give it a shot. A turbo engine designed from the ground up to be turbo i.e: low compression pistons, cams, stronger internals, computer and timing, etc. By taking that a way, what you would have is car that would perform worse then a NA car with the same type of engine (for instance a 4G63T with no turbo would be less then a 4G63 from a nonturbo Eclipse.) Still, the car might not work at all. One night after I had first installed my Greddy intercooler pipes, one of them popped loose, essentially sending all the boosted air into the atmosphere instead of into the engine. The car's computer expects that certain amount of air so the computer felt like something was wrong (the turbo spooled faster without any resistence) so it cut the fuel, making my car run only up to about 2800rpms and its top speed was about 40mph. I had to limp home to fix it. Other cars may differ but you are going to have to do more to just get the car to run without a turbo then just remove it. In short, why bother..just get yourself a high ouput high compression NA motor and mod it up.
Old Sep 7, 2002 | 09:08 PM
StreetLancer's Avatar
I was gonna wait until someone said the same... you're not gonna pawn it like so much unwanted bling-bling?
Seenoevol
Jan 28, 2015 05:14 AM
Sinister8
Feb 28, 2011 06:59 PM
SuckaFree
Lancer Aftermarket Forced Induction Tech
Oct 18, 2005 09:02 PM
Kaymo
283
May 3, 2005 10:23 AM
Michaelk
Nov 22, 2001 08:42 AM
