GReddy Type-S Blowoff Valve install
Old Jun 8, 2004 | 08:59 PM
Ludikraut's Avatar
Just wanted to say thanks again TurboTecnica, between your write-up and the one on EvoMoto, the install was a piece of cake.
The difference between a regular Greddy Type-S and the kit from RRE is that the plain Greddy will not mount on an Evo ... you need the correct adapter flange. It looks like the kit from RRE has a nozzle on the flange, which hooks up to the (sometimes) unused second nozzle on the Greddy BOV. I purchased my kit from Lancershop (which comes with a flange that does not have a nozzle) and I used Silver Surfer's single spring mod on my Greddy, which means that I did not hook anything up to the second nozzle on the Greddy.
IMO the chirp is a little annoying ... can that be, umm, "fixed"? I'm assuming it has something to do with how the BOV opens and closes...
I'm pretty sure the Greddy will handle up to 25psi with no problems,using only one spring and the tension screw... if you're boosting higher than that, you can always use both springs.
l8r)
Old Jun 12, 2004 | 07:39 PM
kenshin's Avatar
Okay, it's time to get this cleared up!
Hi guys,
Something's been bothering me for a while now. It's regarding the position of the BOV.
In TurboTecnica's screenshots (first one), it shows that the stock BOV is positioned on its "side." In a "How to install Type-S BOV..." article at evomoto.com (http://www.evomoto.com/tech_info.php?techID=23), there's another photo of the stock BOV at this same position.
Now, I've also seen photos of the stock BOV installed in an "upright" position. Here are a couple of photos from the K&N Typhoon Air Intake system for the EVO VIII installation manual (see attachments).
SO WHICH ORIENTATION SHOULD THE BOV BE!?!?
I'd like for those Evo owners who HAVE NOT yet messed with the stock BOV to please check their car and let me know.
Thanks a bunch!
Old Jun 12, 2004 | 07:42 PM
Quickshift's Avatar
I beleive they tap into the lower part of the BOV to help keep the plunger in position till you lift off the pedal . So at part throttle it should help be more consistent. I have this bov but not from the RRE guys, I love it and it will hold up to 24 psi from what ive experience first hand. Got mine on ebay for 160 a couple months back new
Old Jun 12, 2004 | 07:44 PM
Quickshift's Avatar
There illustration is incorrect the BOV is backwards in those pics and can cause problems.
Originally Posted by kenshin
Hi guys,
Thanks a bunch!
Old Jun 13, 2004 | 08:11 PM
Ludikraut's Avatar
Evomoto did not have a stock intake on the Evo that they were using to illustrate the install, therefore the stock BOV's position is not the same as it would be on a bone-stock Evo. Turbotecnica's pictures are correct. That is exactly how the stock BOV was installed from the factory on my Evo. It is also exactly how the Greddy Type-S should be positioned. The only things that may differ is your flange kit, which may or may not force you to use all of the connections on the Greddy Type-S BOV.
l8r)
Old Jun 13, 2004 | 09:16 PM
kenshin's Avatar
Thanks guys. It wasn't that I didn't trust TurboTechnica's directions, I just wanted someone to make sure. :-)
Old Jun 13, 2004 | 10:06 PM
egui42's Avatar
Well, I got mine from RRE and they are not pre adjusted because they are the same kits they sell for the 2nd generation eclipse. All cars are different so they don't guarantee that you will not need adjustment. You should make sure after you install it, to drive around and make sure your getting all the boost you had before. If you don't, just tighten or loosen the screw till you get full boost. This is just my .02 cents. I have been told by RRE and DSS to do this.
Old Jun 14, 2004 | 08:21 AM
Ludikraut's Avatar
yeah, you also want to make sure that it isn't too tight, or you may get compressor surge. I saw a bunch of turbo cars over the weekend that had compressor surge - although none with a Greddy Type-S
IMO you should probably start out with the adjustment screw all the way out and then tighten it as needed (ie. if you're leaking boost, tighten it some more).
Old Jun 14, 2004 | 04:39 PM
egui42's Avatar
The adjustment screw should not be to tight or to loose. Try to have it in the middle.
Old Jul 13, 2004 | 01:26 PM
QuikSylver's Avatar
When you say "in the middle", do you mean put the bolt in the middle of the screw? Wouldn't that just rattle off eventually? Im kinda confused as in how to tighten and loosen the setting...I have mine all the way towards the bov, all the way tightened...i just got her today (the bov).
Old Jul 13, 2004 | 07:44 PM
inline4g63's Avatar
quiksylver that is right. YOu want the bolt to be tight and against the BOV. ITs the locking bolt. What equi42 means is that the adjustment screw, the one with the threads, should be adjusted to where half of its length is sticking out. I dont know how long the screw is, but I have mine to 5-6 threads out from the locking bolt. I have mine recirculated. At first I thought it was VTA because I didnt connect the very tiny tiny nipple, I only connected the two main larger pipes. Anyway, still get the whistle sound!
Old Sep 13, 2004 | 11:36 AM
outsider's Avatar
pic is dead
Old Nov 18, 2004 | 11:42 AM
EvO WiD StYLeZ's Avatar
Question
Originally Posted by TurboTecnica
Thanks! It is definitely louder than stock. When partially on the throttle and then letting off, there is the nice GReddy chirp, and if you really get on it.. you hear plenty of wooshing (most of this is from the intake though, I'd imagine) and then the BOV really rips. It sounds great! We couldn't wipe the grin off our faces after it was installed
Im still trying to figure out exactly how the Greddy Type-S sounds (example: any sound from a movie)..?
Oh and if anyone knows how I can get a sound clip of it.. I'd appreciate it..
Thanx
-Gary
Old Nov 18, 2004 | 12:29 PM
egui42's Avatar
more of a whistle, than a whoosh sound. My friends and I love it.
Old Nov 18, 2004 | 06:59 PM
P0300's Avatar
Is this with the stock intake or aftermarket?
