92 or 93 octane same as 100 with WI
Old May 8, 2004 | 08:40 AM
nothere's Avatar
found a quote on the Water Injection board that might peak your interest
here is link to the thread
http://waterinjection.info/phpBB2/viewtopic.php?t=63
(Iknow, I know this quote deals with a different car but the underlining fact should hold true.)
Bruce
I'm getting the WI just for a better afr, yeah right.
Old May 8, 2004 | 10:15 AM
CharlieGsanD's Avatar
Ran Auqumist's W/I system on my last car with rather amazing results...
seeing as i live in Cali we get the 91 pisstane i was having some major problems running 20 Psi on a 9.5-1 comp motor
after installing the W/I i noticed a few things......
lowered detonation/knock count considerably... esp @ high boost
ECU was able to dial in more timing because of the reduced knock (timing = power)
Intake air temps were down almost 40 Deg F compared to when the W/I was off @ similar boost levels
Steam cleaned the carbon out of the Combustion Chamber (instead of a black soot, i could see the concentric rings from machining/casting in the piston head)
nikg
Apr 19, 2012 11:17 AM
Vigman
16
Jun 16, 2010 12:54 AM
nothere
Sep 18, 2009 08:48 PM
allen_petty
May 7, 2008 04:41 PM
nothere
Jun 20, 2004 09:32 AM
