I want a loud BOV but I don't want the stalling issues that come with a VTA BOV. I saw this Turbosmart Dual Port BOV at Lancershop.com and it sounds like it is exactly what I'm looking for. It recirculates so it won't stall, but it also VTA for the sound. I was just wondering if anyone has one or has heard one, is it loud? Is it a good BOV?
Anybody out there have any experience with the Turbosmort Dual Port BOV?
i would suggest the gofastbits blow off valve. it is like the turbosmart valve however its adjustbale in the amount of air which gets recurculated and the amount that gets vented to atmosphere, also the vacumm nipple is adjustable 360 degrees to make mounting easier. it also has adjustments for spring tension like every other valve. i've seen a few cars run this valve and they have had nothing but great things to say. and for them it was the only valve that alowed them to vent to atmosphere while still retaining full driveability.
check this out
gofastbits, stealthFX blow off valve.
Go Fast Bits
also the valve stays closed at normal driving conditions and idle, unlike other valves. "supposedly" the people i talked to say this really helped there throttle response.
check this out
Go Fast Bits
thanks for the imput just did some reading on that bov and it looks like it was made for a wrx, well thats what they used it one.. id like something simple that i dont need to weld if possable. wich i know they are out their
Quote:
http://www.vividracing.com/catalog/p...roducts_id=286Originally Posted by chinto
hrmm interseting... got a price range place in the states to buy it from?
but that's the hybrid, not the stealth model... correct?
Quote:
I dunno. No idea what the difference is. Just saw that Vivid was a dealer for them and checked out their website.Originally Posted by eLiTe eVo
get them MAS connverter from ultimate racing and you can run any BOV (VTA) you want with zero stalling/drivability issues. Too bad it cost 650, but if you got the loot and want the sound it might be worth it.
im sure vivid could get the stealth model, just e-amil them and ask, and why would u wanna go speed density? mas is more accurate and the stock maf sensor is good for up to 450 whp, and not a restriction at all, it all depends on your goals
Quote:
Where is the MAS converter on Vivid Racing's website? I looked all over for it and I couldn't find it. Is it under the EVO stuff or somewhere else?Originally Posted by Guack007
