New Dyno sheet w/GT35R
Old May 11, 2004 | 01:35 PM
EVOlunchbox's Avatar
New Dyno sheet w/GT35R, w/pics...
Well I just got my car back after a long awaited couple of months with a custom GT35R kit installed. Evan Cline former fabricator from Godspeed fabricated the majority of the kit, except for the manifold but he did have to modify it several times to get things to fit right. At the same time he installed a ATS triple plate carbon clutch, Apexi Power FC (D-Jetro), Greddy 740cc injectors, fuel pimp, small battery kit, custom IC piping, Tail wastegate/BV, and other little things. The manifold is from DN performance but the wastegate flange needed to be adjusted a little to fit the new Tail. Also my idle is a little screwed up on the Power FC but will be fixed soon. I also have stock cams, stock bottom end, and a stock head but made 383.3hp and 307ft/lb. This is without cams because I wanted to see what we can make with stock internals in place. This is also on 93oct, no knock, and very safe AF's. I'll post pics of the setup as soon as I get my hands on a digital camera. But here's the dyno sheet.
Edit: Sorry for the ****ty scan, it's my first time.
Attached Thumbnails New Dyno sheet w/GT35R-dyno.gif
Old May 11, 2004 | 01:38 PM
metaphysical's Avatar
Registered User
Seems very low. Your torque is WAY to low. 93 octane or not, that's not a good tune. Dynapacks dyno high.
nastea's Avatar
thats it? i've seen 320ish on a dynapack for an evo with stock turbo, and more torque. A nicely tuned camed evo is putting out 370ish WHP on a dynojet, which would be about 350ish on the dynopack?
are you tuned properly? with that turbo kit i would want to see more then that....
Old May 11, 2004 | 01:55 PM
moses evo's Avatar
Originally Posted by EVOlunchbox
Well I just got my car back after a long awaited couple of months with a custom GT35R kit installed. Dan (Guru) and his crew from Godspeed fabricated the majority of the kit, except for the manifold but he did have to modify it several times to get things to fit right. At the same time he installed a ATS triple plate carbon clutch, Apexi Power FC (D-Jetro), Greddy 740cc injectors, fuel pimp, small battery kit, custom IC piping, Tail wastegate/BV, and other little things. The manifold is from DN performance but the wastegate flange needed to be adjusted a little to fit the new Tail. Also my idle is a little screwed up on the Power FC but will be fixed soon. I also have stock cams, stock bottom end, and a stock head but made 383.3hp and 307ft/lb. This is without cams because I wanted to see what we can make with stock internals in place. This is also on 93oct, no knock, and very safe AF's. I'll post pics of the setup as soon as I get my hands on a digital camera. But here's the dyno sheet.
mate at what bar, very low torque figure should have been near 350 to 360
Old May 11, 2004 | 03:01 PM
maki's Avatar
yeah pretty low number for that turbo
my friend dynoed 350 on stock turbo, only with cams and 660cc injectors
Old May 11, 2004 | 03:55 PM
Mitchubishievo's Avatar
Those sheets are pretty embarassing man, less than 400 WHP and just 310 lb. tq. with a turbo upgrade? Just gets some cams and get tuned better; on a GT35R you should be at about 450 WHP minimum .
Old May 11, 2004 | 04:07 PM
evo542's Avatar
i agree, ditch the stock cams than retune it
Old May 11, 2004 | 04:54 PM
EvolvedfromaWRX's Avatar
how much boost is my questions
Old May 11, 2004 | 06:40 PM
Chris in HB's Avatar
All haters... Not one encouraging word.
The torque is low, but as you stated, it's a very preliminary state of tune with stock internals. I am really curious to see how you end up - congrats on your turbo swap. Check with some of the other swapped guys about how to get those torque numbers up. Keep us posted.
Old May 11, 2004 | 06:47 PM
justrick's Avatar
nice preliminary numbers. ill bet when you lean that out to about 12.7 to 1 and add some timing that torque figure is going to go through the roof. cant wait too see the new numbers.. congrats on that sweet a** turbo setup..
MrBonus's Avatar
Did you tune the car completely with the Power FC Commander or did you use the software?
Old May 11, 2004 | 06:50 PM
en1gma19's Avatar
ummm, i think its dynojets dynos high. dynapack is fairly close. dyno dynamics ande mustang dyno are almost exact.
Old May 11, 2004 | 07:36 PM
I'm running around 1.5 bar~21psi
Thanks man, I'll let you know what happens after I get cams/head.
Originally Posted by MrBonus
Did you tune the car completely with the Power FC Commander or did you use the software?.
Unfortunately the car was tuned completly from the commander... Thats why my idle sucks so bad.
Either I need to get datalogic, or have someone from one of the few Power Excel dealerships come and tune it here. I am way too far away to drive to Texas or Cali.
Old May 11, 2004 | 07:38 PM
94AWDcoupe's Avatar
Big turbo at low boost. Not surprising the low torque. Prolly also has the 82 exhaust housing too. I put stock cams back in my car once just to see how it would perfom. It was like puttin a rag over the intake of the turbo.
Old May 11, 2004 | 07:42 PM
So you think the low torque numbers now are due to not having cams?
Also I'm not exactly sure what the sizes on the turbo are. I'm pretty sure your right. All that I know about it is that it's directly from Garett
