Stock BOOST!!!!
Old May 13, 2004 | 01:57 PM
Yaroslav's Avatar
Exclamation Stock BOOST!!!!
[IMG]Can someone tell me what is your stock boost 0.8 or 1.3?????
My boost controller shows 0.87
Answer PLEEEEEEEASE!!!!
[/IMG]
Old May 13, 2004 | 05:34 PM
EVILEIGHT's Avatar
I believe stock boost is 19-19.5psi @ 3500 rpm. I am not an expert at conversions but i think that is close to 1.3 bar.
Sorry I don't know for sure, my profec b is set to 19.8 psi unless on race gas.
Cheers,
Aaron/Evil8
Old May 13, 2004 | 06:33 PM
DanD's Avatar
What boost controller do you have? I have the HKS EVC IV on my eclipse and when you set the boost controller up the lowest setting will not be the stock boost but at the amount of pressure the wastegate opens at. Here is a website that can help you with pressure conversions: http://www.unit-conversion.info/pressure.html
Old May 13, 2004 | 07:34 PM
dansplace's Avatar
My stock boost is about 1.3bar sustained and should be about 1.45bar peak. Although others have hit 1.5bar with heavy loading. But with your BC, you can tune the boost down or up to suit your driving style and needs.
Old May 13, 2004 | 08:55 PM
1QWKEVO's Avatar
.87 is with the boost controller "turned off"... the wastegate opens at 11 psi!!!!!
Old May 13, 2004 | 09:29 PM
maki's Avatar
[/IMG]
do you have a manual boost controller?
i was a big fan, but now im know mbc are sh.t
Old May 14, 2004 | 12:22 AM
Yaroslav's Avatar
I have Apexi AVC-R.
My settings:
BOOST 0,87
DUTY 40%
scramble - off
Learning gears -on
feedback speed -off
start duty-off
Old May 14, 2004 | 12:26 AM
Basic|Evo's Avatar
thats why i had the apexi in my wrx to reach the bosst you want its boost and duty do u have a bosst gauge?
Old May 14, 2004 | 02:28 PM
Yaroslav's Avatar
no i don`t,but my BC has
