Turbo Back question
Old May 14, 2004 | 05:21 PM
SEVEN's Avatar
Turbo Back question
My EVO, has only a Turbo Back exhaust....everything else is stock, so my question is...Will i get flames out of my exhaust?
Old May 14, 2004 | 05:43 PM
ChrisS.'s Avatar
Possible, but not likely with stock ECU settings.
You would have to be running real rich for this to happen. If you had an SAFC hooked up, its possible. I used to shoot flames out the back of my eclipse all the time (when racing) due to running rich.
Old May 14, 2004 | 06:39 PM
Fourdoor's Avatar
Hell, he is MORE likely to shoot flams with the stock ECU running things.... it runs pig rich from the factory and we use the SAFC to lean it out! It all depends on weather your turbo back exhaust has a CAT. CAT = no flames.
Keith
Old May 14, 2004 | 06:56 PM
SEVEN's Avatar
Keith
Thats what i thought, since it runs very rich from the factory, and i have no cat
Anyway, thanks for the help guys
Old May 14, 2004 | 06:58 PM
ChrisS.'s Avatar
Yes, if he sets his SAFC to correct settings. In my Eclipse I was running rich still, so before the SAFC no flames, after ALOT .....all depends on settings.....
But I agree the car is rich from factory, I have way more power now on the top end.. due to exhaust and the AFC..........
