does an ebc compensate for altitude and weather?
Old May 16, 2004 | 03:23 PM
budlong's Avatar
i thought it did compensate for weather and altitude, but after reading some posts about the profec b II, im not so sure.
are the hks and blitz easier to set and forget?
BUDLoNG
Old May 16, 2004 | 03:26 PM
MalibuJack's Avatar
Only closed loop electronic boost controllers (Apexi S-AVCR for example) will compensate.. Actually, its not all that complex, since all the closed loop controllers do is try to hit a target boost, and ramp-curve. I don't know much about the less expensive controllers, but many of the inexpensive Electronic boost controllers will control boost, and can be tuned for spiking.. But would generally need periodic adjustment in the same way a Manual Boost controller might.
Old May 17, 2004 | 10:17 PM
budlong's Avatar
bump
Old May 17, 2004 | 10:29 PM
MalibuJack's Avatar
http://www.blitz-na.com/boostcontroller.html
According to the blitz site, they have 4 boost controllers, the top of the line does closed loop(target boost).. HKS I can't tell you though..
