S-AFC + VTA BOV = Does it really work?
Old May 23, 2004 | 05:02 PM
[Cyanide]'s Avatar
Yes?
No?
Does an S-AFC actually help with a vent-to-atmosphere blow-off-valve in making the car not stall between shifts?
Old May 23, 2004 | 05:14 PM
GOKOU's Avatar
No. Don't VTA. Too much sacrifice in drivability unless you don't care about that.
Old May 23, 2004 | 05:25 PM
Quickshift's Avatar
It does not have control of the idle unlike the HKS-AFR unit. So running vta with a s-afc will sacrifice alot of drivabilty in a hard way.
Old May 23, 2004 | 08:17 PM
GTVEVO's Avatar
Plain and simple no it doesn't. SAFC can't control it on a MAF/Karmen car.
Old May 23, 2004 | 08:22 PM
Quickshift's Avatar
S-afc can control the karmen signals, it cannot control the MAF sensor though..
Old May 23, 2004 | 08:27 PM
differentstroke's Avatar
the only way you can use a VTA is with UR blowthrough MAF its $650and its suppose to get rid of eradict data logs on a cone filter setup
Old May 23, 2004 | 08:46 PM
mprtklr's Avatar
the S-AFC DOES control the MAS sensor..thats exactly what it controls, and thats it, and it cannot compensate for VTA
Old May 24, 2004 | 04:32 PM
mdzuricky77's Avatar
I VTA for month with the Safc and only had minor idle issues for the first two weeks. After that all was well.
Old May 24, 2004 | 04:54 PM
93h22cvc's Avatar
no it will not help at all
Old May 24, 2004 | 05:00 PM
BlazeGT4's Avatar
HKS has a new product called the EIDS.
It will correct the erratic idle so that you can vta.
Retail is around 125. Not bad. But it's a lot of $$ to pay for noise....
http://hksusa.com/products/?id=2175
Cheers,
Jason
Old May 30, 2004 | 09:36 PM
forum04pl's Avatar
so if you have a hks afr will you be able to vta?
Old May 31, 2004 | 11:36 AM
evo542's Avatar
yes
Old May 31, 2004 | 11:41 AM
evo542's Avatar
the best possible way to do it is like someone stated earlier, get the MAF blowthrough system, you can VTA and have 500whp using the STOCK ecu
Old May 31, 2004 | 01:35 PM
showoff's Avatar
Who sells the HKS EIDS?
Old May 31, 2004 | 03:39 PM
BlazeGT4's Avatar
No.
The HKS afr is an Air Fuel Ratio device. However it alters your mixture based on RPM levels. It will not "regulate" the stumble cause by VTA. You will still need the EIDS or similar device.
HKS products can be puchased anywhere. Try online at www.hksusa.com and search for local dealers near you. Please note....I called around looking for the EIDS and my local shop did not know what I was talking about. So don't be suprised if they give you some funny looks.
