HKS vs Jun vs Tomei vs Piper vs Works vs etc...
Old May 27, 2004 | 11:42 AM
Fenris Ulf's Avatar
Originally Posted by sayanara
The Jun cams have more lift compared with the HKS don't they? Also does anyone know if having more lift translates to a lower rev limit, therefore having cams with not as much lift and longer duration will enable you to rev higher??
Max lift really only concerns ptv issues and coilbind. It is the ramp rate that dictates how stiff the valvesprings need to be and thus has a much more direct effect on what rpm valve float occurs. There is no way to tell what the ramp rates are for a cam just by looking at the advertised duration numbers and max lift. Since there are 4G63s revving to 9 grand with the Jun cams I really doubt valve float is a concern with the proper valvetrain components.
Old May 27, 2004 | 10:31 PM
sayanara's Avatar
thanks Fenris Ulf
Martin@AMS
836
Oct 6, 2016 09:11 AM
TheBoz
Mar 7, 2016 07:54 AM
alpinaturbo
Apr 13, 2011 01:44 PM
AMS
Automotosports - Illinois
123
Oct 7, 2007 04:03 PM
RyanM
28
Jun 20, 2006 12:21 PM
