Induction pipe for stock airbox
Old May 28, 2004 | 09:39 AM
k270kmh's Avatar
Question Induction pipe for stock airbox
There is many topics about air filters. In my opinion the drop in type is the best one, but I couldn't find anything about air inlet pipes.
It would be good to put here all information possible to understand what kind of performance improvement it can give.
Raises turbo lag? Needs a high amount of boost than stock? Is better/worse to avoid engine heat? some dyno test? etc...
Old May 28, 2004 | 11:30 AM
Karash's Avatar
it straightens the airflow more after the sensor. The stock intake 'pipe' is like an accordian
Old May 28, 2004 | 01:13 PM
k270kmh's Avatar
But, It really works? Add some wheel hp or not?
Old May 28, 2004 | 01:53 PM
Aby@MIL.SPEC's Avatar
Who make's the red induction pipe in the original post?
Are both of the pipes shown a direct replacement of the factory piece which allows you to maintain the stock airbox?
Old May 28, 2004 | 01:55 PM
Guack007's Avatar
The reason I went with a KN drop in panel and stock airbox is because I dont want any wierd MAS readings and any drivability issues. Do these after MAS pipes cause any problems? Any one have any first hand experience?
Old May 28, 2004 | 01:57 PM
Nesiop's Avatar
Ralliart.
Old May 28, 2004 | 02:11 PM
jcnel_evo8's Avatar
Its just far enough into the air track to cause some noticable things to happen. Most people who get them also have a tune done.
jcnel.
Old May 28, 2004 | 04:00 PM
k270kmh's Avatar
What kind of tune? I was thinking of installing this air inlet pipe with my stock car... maybe it is not a good idea... /?/
Old May 28, 2004 | 04:20 PM
jcnel_evo8's Avatar
I had the same question when I was changing over the stock intercooler hoses to some nice SAMCO ones. After about 1/2 day research (including a comment from Dave Buschur) I came to the conclusion that it would need a tune.
I think the idea here is the accordian type hose restricts the air a bit and if more air were allowed using a hard and straighter pipe, the processor would see more air and try to make the EVO run even richer thereby killing somemore performance. So...with that said, the stock computer has a pretty small window to compensate for Volumetric Effeciency changes such as induction changes, and cams.
Personally I don't think you'll 'damage' anything...but I've already planned this upgrade for when I can get all of my ducks together...which is...exhaust...computer...o2 tuning sensor.
Thanks,
0.02.
jcnel.
Old May 28, 2004 | 04:35 PM
naucrx's Avatar
I was also told that a new induction pipe on the EVO would require a tune because it allows too much air to flow through.
I was personally looking at getting the one from Dejon Tool before I found out that I needed some tuning to accomodate the new pipe. If I recall, theirs was the least expensive of all the ones I could find, at $140.
http://www.dejontool.com/Evolution.htm
Old May 28, 2004 | 04:49 PM
k270kmh's Avatar
Is the Ralliart ECU the correct tool for this tune job?
I know that this ECU change the air/fuel ratio, but I don't know if this ECU was created for use with another Ralliart parts like air inlet pipe and intercooler pipe... I guess so
razorlab
Apr 2, 2016 11:01 PM
Mellon Racing
EvoX 'For Sale' External Engine / Power
30
Feb 25, 2011 02:33 PM
Rollaway
Jan 20, 2006 03:15 PM
beast464
Jan 28, 2005 09:51 AM
Boost Solutions
Jul 21, 2004 03:55 PM
