Gains with DP on stock exhaust??
I'm curious to know if anyone has seen noticeable gains after only upgrading their dp and still using the stock cat and stock exhaust? A while back, in a past thread that I found by searching, TurboTrixRacing and Grod101 claimed to have seen a stock evo gain 20 whp from an RMR dp with stock cat and exhaust.
Has anyone seen similar gains to verify that this wasn't juss an anomaly??
If so, it'd be sweet to keep your car looking stock on the outside so as not to attract negative attention, but still be faster than stock. Not to mention saving $600 on a catback exhaust!
i highly doubt theres that much gain with or without an exhaust... i'm running a cat back on stock dp and cat and the car responds alot better then the stock catback did... faster spool, pulls throughout the whole powerband... etc
Considering that the stock catback is 2 3/8 with the stock DP coming in a 2" with a number of crush sections your best best is running a 2.5" DP at the most so as not to create even more backpressure. I had an HKS DP on my car which comes in at 2.6" inner diameter and untuned it picked up from a stop smoother, boost came on a little quicker although I was experiencing some timing pull accross the middle. Combined with some type of ECU tuning and a slip fit 2.5" High Flow Cat I think the stock catback piping is still useful, and best of all suppresses sound while still freeing things up enough to make smoother power, with noticeably quicker spool up.
i just have the rmr downpipe with stock exhaust and cat. Thanks turbotrix. it feels alot like there alot more torque. sounds deeper too (meaner) the whole engine.
exhausts just cost soo much.
i have the helix 3 inch and the d&d cat back on the stock cat... definately felt a difference when i put it on... the stock dp is a restrictor compared to the rest of the exhaust.
Geese, I'm going to sound like a Buschur spokesman today... for the most power per dollar, you'd probably best be served by a Buscher 2.5" DP. Then go to the local muffler shop with a rear section flange bought from RRE to have a muffler delete pipe fabbed up (if you are that short on cash). If you have a little more of the green stuff on hand, You can pick up a Megan Racing 3" DP and cat back for less than $500 off of Ebay.
Originally Posted by Ev0 1
So whats the best dp to get if i was to keep the stock cat and exhaust? (i would get the full turbo back but on a tight budget at the moment)
Works claims that their 70mm dp is the best size when using the stock turbo. (even better than a 76mm dp) They reccommend a 76mm (3 inch) DP for their upgraded turbo. I've heard that this is a common strategy for many tuner evo's in Japan. (70mm dp with stock turbo)
I doubt, however that any of us would be able to tell the difference between a 70mm and 76mm downpipe, in the real world.
I would add, however, despite a tight budget, it would be worth a little money to get an aftermarket AB exhaust in addition to your DP. I got my Works AB used for $125 and it added lots of power (on the butt dyno) over the restrictive stock muffler.
Good luck!
LOL
