Do you guys recommend anti-seize on the spark plug threads?
Originally Posted by WOT
How do you know if you received a PO300 code? Via check engine light? I have tried 3 different plug types to date, while swapping the stockers in between.
The whole time I have used both anti-sieze & copperslip.
No CEL to date.
Torque reduction? Hell, if the threads are bone dry, you potentially will receive a false torque reading due to binding.....WTF
Good luck with what you decide.
No CEL to date.
From what I have seen there is no universal answer and to date I have yet to see a manufacture state that anti-seize shall be used when installing plugs. Mitsubishi is no exception. In fact I have never found anti-seize remains on any stock plugs without regard to the manufacture.
Where did I say that I had a P0300 from a plug install issue or for that matter a misfire problem?
Denso's catalog states reduction in torque by 50% when threads are lubricated or 9 ft-lbs for the Evo. This seems really low - thus I asked what people are torquing their plugs to with anti-seize.
As far as reducing torque by 50%????????????? Dont believe everything you read. If you do such, be certain to have the necessary tools to replace the spark plug that pop's out! Probably not possible since the plug should be captured by the coil. You'll just wobble / enlarge the plug hole / threads, then rat-f##k yourself the next time you replace the plugs & blame on the copperslip because of improper torque! Never the less, just torque it up to the bottom-side factory specs. We apply compound everytime we remove plugs for borescoping, leak-down, plug test, etc. I can tell you we havent had a thread related issue. The primary reason for applying sauce in the 1st place.
If you ever had a plug seize in a aluminum head before, you will religously apply some type of compound. For those who havent, are most likely skeptics.
FYI,
Denso replied with the following recommondation,
I do not recommend anti-seize on the plugs. It does not allow for the heat to dissipate correctly. Please do not use anti-seize.
FYI,
J/KGood luck with your decision.
FYI,
Think about that for a minute. The anti-seize also increases the surface area contact of the plug to the head, thus allowing better heat transfer. Anyone who has built computers for a hobby knows what I'm talking about.
Use the copper anti-seize others have mentioned. (heck, I didn't even know copper anti-seize existed. Where do you get that?)
The key is to use a really small amount.
Wurth CU-800 Copper Anti-Seize
mcm308
Dec 13, 2010 12:08 PM
LaXGSR
10
Aug 3, 2010 02:10 PM
