What boost controller...?? Rock steady boost, no exaggerating.
Old Jun 10, 2004 | 10:06 AM
93civEJ1's Avatar
What do you guys recommend for rock steady boost?? I am planning on doing a MBC...leaning more towards the Hallman Pro RX or whatever its called...What do you guys recommend...I want my boost to go over, Peg 20psi, and stay there, no spiking, and no tapering...I want the best. Any opinions?? feel free to begin now!
Old Jun 10, 2004 | 11:51 AM
MrBonus's Avatar
TurboSmart E-Boost.
I dumped my Profec B - Spec II and this thing is ****ing FANTASTIC. I wanted Agile to print out a picture of my boost curve. It was a thing of beauty.
Old Jun 10, 2004 | 11:55 AM
992gnt's Avatar
I've had really good luck with the TurboXS HP. 20psi, period. This is the second car I've run one on and I recommend them to anyone that will listen.
93civEJ1's Avatar
yes...this thing has crossed my mind...if I go with an electronic controller...it would def be this one, but it is a little bit bigger than i would be able to fit in my pod...it would be nice though...where do you put yours?? I am wanting a hallman otherwise...
Old Jun 10, 2004 | 11:57 AM
SinCityEvo's Avatar
My Hallman Pro RX holds solid 20-21 to redline with a very slight taper. Easy to adjust also.
Old Jun 10, 2004 | 11:59 AM
Eric Lyublinsky's Avatar
the EX works great too if you need somthing a bit cheaper Turbotrix has them in stock
93civEJ1's Avatar
where did you get it from?? Im actually thinking about ordering one today or something...
Old Jun 10, 2004 | 12:13 PM
GottaGoFaster's Avatar
Mine too
Old Jun 10, 2004 | 12:17 PM
93civEJ1's Avatar
ok ok ok...stop torturing me...where has these in stock for a very excellent price??
Old Jun 10, 2004 | 12:20 PM
Turbotrix.com
100 bucks.
Old Jun 10, 2004 | 12:22 PM
siantjab's Avatar
Hallman Pro RX in mine holds rock steady at whatever I set it to. I HIGHLY reccomend it to anyone. Good peice, nice quality, and fairly easy install and setup.
Good luck!
Old Jun 10, 2004 | 12:24 PM
93civEJ1's Avatar
Originally Posted by Eric Lyublinsky
Turbotrix.com
100 bucks.
for the Pro RX like everyone is stating?? If not....where can i find one?? thanks!
Old Jun 10, 2004 | 08:10 PM
JDM_EVOVIII's Avatar
I have the Turbo XS MBC and I blew it the day I installed it. The metal body that houses the 2 rubber rings are spewing air when I open the valve to up the boost. I'm now only hitting 1.2 bar-1.3 bar and it's slow as hell right now. I'm pissed, can't you tell. A local tuning shop in Carrollton, Tx is ordering me another MBC. I'm sure it will work fine, but I'll let you know when I get it installed.
Old Jun 10, 2004 | 08:53 PM
Invoice EVO's Avatar
Veteran: Air Force
Turbosmart in cabin MBC. Works well with a slight taper at redline.
Old Jun 10, 2004 | 10:02 PM
GREDDY's Avatar
Turboxs HPmbc. It holds boost to redline!
