Gears get stuck when race shifting? PLZ HELP!
Old Jun 14, 2004 | 07:33 PM
XRS-Lift's Avatar
im good at 7k rpms now but a slight pause at 7,800 ill loosen it a bit more later.
Old Apr 7, 2005 | 05:43 AM
caymandiver75's Avatar
Originally Posted by XRS-Lift
Hey i recently changed my clutch and now i cant shift when racing. if i rev high {7k} i cant put the car in the next gear. Do i have to change my tranny fluid to something else? Right now i have mitsu spec fluid. And is it even the tranny fluid thats causing thhis? If i got redline tranny fluid would it solve my problem? plz help!
I'm now having the same problem. Car was fine with stock clutch and now that I replaced it with a new one i can't shift when i rev hight like 7k and up into the next gear. Do you know what specs the manual says for clutch adjustment?
Old Dec 19, 2005 | 07:03 AM
I'mStock's Avatar
I'm having this shifting problem with the stock clutch... Anyone else?
Old Dec 19, 2005 | 08:57 AM
ACTman's Avatar
Usually adjustment will do the trick, but there are also known problems with syncros, etc. There was also much speculation making it too much trouble to try and farily sum it all up in one post. Search under threads with "lockout" in the title and I think you will find plenty information.
