Stock 03 Evo Cam shaft specs??
I hope this helps.
Engine Model 4G63
Horsepower @ RPM -- BHP 271 @ 6500
Torque @ RPM -- ft-lbs 273 @ 3500
Redline 7000 RPM
Engine Displacement 121.8 cu. in. (1997 cu. cm)
Number of cylinders, arrangement In-line 4 cylinder
Bore 3.35 in (85.0 mm)
Stroke 3.46 in (88.0 mm)
Compression Ratio 8.8
Engine Block / Cylinder Head Cast Iron, Aluminum
Thermostat Opening Temp. 176.0° F (80.0° C)
Spark Plugs NGK IGR7A-G
Spark Plug Gap .024-.027 in (0.6-0.7 mm)
Firing Order 1-3-4-2
Intake Valve Timing Opens (BTDC) 17°
Closes (ABDC) 59°
Exhaust Valve Timing Opens (BBDC) 57°
Closes (ATDC) 15°
Base ignition timing 5° BTDC (+/- 3°)
Base ignition timing, high altitude + 5°-10° BTDC
Ignition timing, normal driving +/- 7° BTDC
Manifold vacuum, min 15 in/Hg (51 kPa)
Oil pressure, idle 4.2 psi (29 kPa)
Oil pressure, over 3500 RPM 43-100psi (294-686 kPa)
Engine Model 4G63
Redline 7000 RPM
Closes (ABDC) 59°
Closes (ATDC) 15°
Solo II Evo
For Sale - Wheels / Tires
14
Apr 29, 2010 06:15 PM
Evokid03
Jan 22, 2010 10:35 PM
Speed Element
61
Sep 25, 2008 11:36 AM
EatSleepBoost
18
Feb 14, 2008 09:48 PM
