Just got HKS'ed Today!
Old Jun 21, 2004 | 08:36 PM
Ludikraut's Avatar
Originally Posted by RaleighEVOVIII
Ok i guess im wrong on this one. then can someone explain to me why i get a nice soot build up on my bumper right above the outlet of the pipe?
Generally speaking, if you get a lot of soot buildup it means you're running rich - although the only way to find that out is to either get a wideband O2 (lambda) sensor and meter installed or get your car on a dyno with a wideband O2 sensor ... might also mean that your exhaust tip is too close to the bumper.
... keep searching the forums for info on this stuff. If you want to learn, the info is there, just make REAL sure that you double/triple/quadruple check anything that anyone says. Better yet, read all the info, come to whatever conclusion you think is right and then verify it for yourself
l8r)
Old Jun 21, 2004 | 09:28 PM
ImportUpgrade's Avatar
I absolutely love my HKS aftermarket parts, they are very highquality and great products!
Old Jun 21, 2004 | 09:46 PM
SinCityEvo's Avatar
That smell I thought was normal until I looked at my rear bumper and it was melted into the exhaust tip. Easy fix though. Just cut back the arch to give the huge HKS tip some more room.
Old Jun 22, 2004 | 01:39 AM
NOVA EVO's Avatar
My exhaust tip clears the bumper easily...no worries...
Old Jun 22, 2004 | 05:14 AM
robvii's Avatar
you can buy cover plates to protect your bumper they are dead cheap and simply self tap in underneath.
ALL evo's run rich standard. period...
by installing breathing mods such as zorst and filter, you are effectively helping more air in/through hence running slightly leaner. but there is plenty of fuel there for safety reasons
Old Jun 22, 2004 | 05:29 AM
evo 8 ya's Avatar
I bet he's running lean. That HKS suction kit really leans the car out.
NOVAEVO
I would just drive the car easy untill you get your flash or untill you can check you A/F ratio. That suction kit leaned mine out alot.
Old Jun 22, 2004 | 07:15 AM
NOVA EVO's Avatar
NOVAEVO
The Evo runs so pig rich from the factory, I seriously doubt the HKS Suction intake will lean it out enough to be dangerous...
Old Jun 22, 2004 | 07:39 AM
Ludikraut's Avatar
I wouldn't bet my 30K car on that ... just running w/out a filter, using the stock airbox, leans it out by ~1 point. If you're going to install the HKS intake, I'd highly recommend checking your AFR, because it will mess with the MAF readings the ECU is getting.
l8r)
