BR580 Install
Hope the install on the turbo kit went very easy for you. We are doing a complete assembly on all the turbo kits before they leave here. The turbo is bolted to the manifold, the 02 housing is bolted to the turbo and the oil feed and return lines are bolted on. All you have to do is bolt the complete assembly to the car and hook up the oil lines, bypass the water line and put the fan on and it is ready to run. Nice right?
David Buschur
www.buschurracing.com
David Buschur
jerastan,Go and have some mod,like intercoler,Jun 2.2 kit,HKS oil coler,Port&Polish,Rebalancing and blue-printing.
You don't think his current mod list is impressive enough?
Originally Posted by Ang Wen Yan
Hi,
how come the oil feed line is going down towards the block? Did you re-route it that way to feed from the block rather then from the head, or do evo 8s get their oil feed to the turbo from the bottom?
