Estimated reflash WHP gain with these mods...
Old Jul 21, 2004 | 09:35 AM
naucrx's Avatar
Originally Posted by midwestmonster
Isn't SES for the airbags??? If it was because of a test pipe, CEL would come on.
You are thinking of SRS, that's the acronym for the airbags.
SES = Service Engine Soon
SRS = Supplemental Restraint System
ZeroFrost, you may want to remove your K&N Typhoon intake. I've heard that intake causes nothing but problems on EVOs. Read this thread: https://www.evolutionm.net/forums/sh...ad.php?t=84166
Your mod list is VERY close to mine with the exception of the Intake. I have a K&N Drop-in instead, and I do not get a fuel cut or hard studder like you described. I am running 20 pounds of boost on the stock fuel pump with a TurboXS MBC.
I've also thrown the p0300 code, twice. I did not experience any fuel cut or hard studder when it happened.
Old Jul 21, 2004 | 09:44 AM
TampaTurbo's Avatar
I tell you what. I have the KN typhoon intake and when I initially put it on, it comes really oiled. Under boost excess oil gets on the MAF sensor. All I did was clean it with rubbing alcohol and it works great. Before I cleaned it, it did run crappy. It would stutter at high RPMs. There is a lot of air that it takes in because before my car was dyno flashed, the A/F ratios throughout the entire power band in all gears were lean (stock ecu). I was shocked that when i heard that the cars run rich I would have seen a nice balance. In my opinion, its a great filter, the MAF sensor just needs to be cleaned and the ECU tuned.
Old Jul 21, 2004 | 10:15 AM
ZeroFrost's Avatar
ok, will do. But how do i clean the MAF sensor?
Old Jul 21, 2004 | 10:21 AM
siantjab's Avatar
^^ VERY carfully!! It will break very easy. Try some light alcohol on a soft cotton swab and clean it VERY VERY gently.
Good luck!
BTW, with those mods and a flash (I have Dynoflash and love it!) you'll be near or just under 300 HP. That's about a 50 - 60 HP gain from stock; just like your freind.
Old Jul 21, 2004 | 01:12 PM
TampaTurbo's Avatar
You will have to take the filter off and just the stock portion of the intake thats attached to the inlet pipe. You'll need to wrench on the bolt that holds the carbon fiber down to the chassis. Loosen the ring and remove the filter. Loosen the ring that holds the MAF to the inlet. Pull it out and either spray rubbing alcohol onto the sensor or pour it on it. Either way as long as alcohol is on it, it will break up the oil and gently take a q-tip and wipe it thoroughly and repeat a couple times to ensure its clean.
Old Jul 22, 2004 | 02:06 PM
SSKILLA's Avatar
wont the alcohol scre the sensor
Old Jul 22, 2004 | 02:15 PM
TampaTurbo's Avatar
Not that I am aware of, in fact I was told to do this by quite a few people. It works. I'm not saying to use like 100 proof. Just some type of medics rubbing alcohol.
Old Jul 22, 2004 | 08:38 PM
ZeroFrost's Avatar
Well i took off the K&N and put on the stock box, im just going to get a HKS filter swap or the HKS RS intake, i hear they work perfect on EVO's. But the DYNOFLASH day has moved to august so now im getting a fuel pump and 264 Cams b4 i go.
Old Jul 23, 2004 | 05:35 AM
TampaTurbo's Avatar
Well let me know if that corrects your problem because you may still need to clean the sensor if there is oil on it.
Old Jul 23, 2004 | 05:45 AM
SterlingEvo's Avatar
As far as dyno #'s, it depends on what type you use, but I put down around 300WHP and 325WTQ on a Dynapak (and later 290whp on a Mustang dyno) with similar mods from Buschur + custom Dynoflash. Essentially what you have equates to Buschur's Stage 1 (minus the SAFC - which you don't really need with the flash, unless you want to fine-tune stuff at the track...). I am running the high-flow cat, though... not the test pipe.
joonvang
Dec 10, 2016 04:55 AM
Gruppe-S
May 14, 2007 05:04 PM
Blue Evo 8
Automotosports - Illinois
11
Apr 21, 2007 08:46 AM
evoIX15
16
Mar 15, 2007 10:48 AM
TurboWill
Northeast Region
Dec 31, 2003 12:34 AM
