stock boost levels?
Old Jul 22, 2004 | 01:43 PM
darkjediii's Avatar
Originally Posted by evo8nj
i think you'd be able to hear a leak that big..
do you have a shop nearby that can check the pressure for you?
yeah but I'm trying to avoid taking it anywhere, might be a simple fix. My exhaust is pretty darn loud so i doubt i'd be able to hear a leak.
Old Jul 22, 2004 | 04:06 PM
darkjediii's Avatar
Ok, I just got done checking all the hoses, retightened everything, still did not fix it however i found that i am missing one (out of four) clamp from the airbox, that should not affect anything right? Any other suggestions on what to check?
Old Jul 22, 2004 | 05:30 PM
EM@WORKS's Avatar
According to Mitsubishi, you should be peaking at 19psi (1.31bar) by 3500RPM with a taper down to 16psi (1.10bar) by 6500RPM. This is in 3rd gear. As the gear goes up (higher load) the peak boost occurs at a lower RPM (more flow through the exhaust manifold). These figures are measured during WOT (Wide Open Throttle).
Hope this helps.
The WORKS Brain Flash P2 holds 19+psi all the way to redline. No taper.
Old Jul 22, 2004 | 07:53 PM
LateSleeper's Avatar
The previous owner may have had a boost controller installed. Check your vacuum lines under the air box. There's a solinoid under there. You'll be able to trace the vacuum lines from the solinoid to the wastegate actuator and turbo housing. It maybe worth spending the $20 to get a new replacement set of lines.
Old Jul 22, 2004 | 08:41 PM
darkjediii's Avatar
yeah it looks like the previous owner had a MBC...
I checked the connections and made sure everything was tight, you think the lines themselves have a leak?
Old Jul 22, 2004 | 08:53 PM
The vacuum lines are no good if they are stretched and yanked. Being that the lines are hard to remove, I wouldn't be surprised if the previous owner beat the crap out of them when the MBC was installed. Another thing to is that the restrictor in the short line to the turbo housing may be missing. This will cause a low boost condition.
Old Jul 22, 2004 | 09:02 PM
darkjediii's Avatar
ahh thanks, ill check that tommorow morning, what does the restrictor look like?
Old Jul 23, 2004 | 06:41 AM
k270kmh's Avatar
If can`t find a leak, go to a Mitsu Dealer and ask for a check.
I would check the boost gauge conections too...
Old Jul 23, 2004 | 06:47 AM
siantjab's Avatar
Yeah, check the gauge connection. I have an autometer (not my first) and it's dead on; just like all the others. Too many people are quick to slam autometer, but they do make decent gauges.
Make sure all the boost lines are on in correct order. If the previous owner removed them and re-installed them he may have forgotten the proper patter (especially the line under the MAF pipe). If you need the routing diagram for the vacuum lines it's under your hood on the right hand side.
Good Luck!
Old Jul 23, 2004 | 02:12 PM
darkjediii's Avatar
Good Luck!
Ok looks like the previous owner did not reconnect the vacum hoses on the boost selonoid correctly, one line was just capped off everything is now hooked up right, I reset the ecu by taking out the negative terminal for 5 mins.. it helped a little bit but still getting only 14psi, I took the car to a shop to see if its the boost guage, they tested it and said it was accurate. had them double check everything and they said that all the connections are right and all clamps are tight..
so now im only getting 14psi what else could it be??!
Is it possible that the ECU needs to relearn before it kicks up to full boost? what are possible error conditions that would make the ECU pull boost?
Old Jul 23, 2004 | 03:12 PM
darkjediii's Avatar
where's the best place to get the replacement lines? i dont want to go to the dealership and be charged an arm and a leg! thanks
Old Jul 23, 2004 | 04:53 PM
EM@WORKS's Avatar
We can sell you a brand new stock hose assembly for $15 as we stock many genuine parts. We'll also sell anyone 5 factory oil filters for $25 if you mention this post.
www.worksrally.com
415.641.9675
