upto 400 HP on stock turbo???
Get the APEXI instead. Much higher quality. Mainly, it can run normally closed like a mbc. This also means you aren't losing boost just before you set the gm to close. Basically the gm is cycling all the time whenever you boost. If the gm fails, you have full boost! This is an awesome piece if you want to go to the hassle of controlling boost with the aem...
Talk to Mark at www.Quantum-racing.com for faq
