Forced Performance Evo 8 turbo housing. 10.5cm2 worth it?
Well I was waiting for forced performance to do something with the evo's. but for $245 bucks which is really cheap, a larger housing, is that worth it? im a turbo newbie so what are the real benefits of this?
http://linux.forcedperformance.net/m...ode=Lancer_EVO
there is the link.
thanks
anyone have it already?
there is the link.
thanks
thats very interesting...i have had two turbo's on previous cars from FP and they are some of the finest i have ever seen...FP usually does not joke around with their products.
i'm hoping someone will purchase this shell out some good dyno numbers
Is this the same unit slated for the 2005? It seems to fit the description.
"+5 hp increase / +13 lb-ft increase, due to larger diameter turbo nozzle (9.8 -->10.5) and new waste gate shape (oval --> circle) for improved boost response"
http://media.mitsubishicars.com/deta...54184&mime=ASC
Vishnu I think has reported slower spool with this housing which is not surprising. The interesting question is how this housing would spool with the ti turbo that FP offers. Same as stock, slower or faster?
Originally Posted by alleggerita
I believe it is. But on the MR cams, engine managment, wastegate, etc. are all adapted to it.
http://linux.forcedperformance.net/m...e=Lancer_Turbo
It looks like that turbo uses the same housing. Surely someone has bolted one of these onto an Evo8 and tuned it. Right?
I ordered a 10.5 housing, I have a 9.8 titanium wheel turbo so I won't sacrifice the spool for the larger housing..
Basically you will increase turbo lag slightly on a stock evo8 turbo.. It has some benefits, but if you REALLY want to work with the stockish turb you need to focus on optimizing more than just a bigger turbo housing.. Reduce any restriction in the intake and exhaust that you can find..
There is still alot (relative) performance to be gained with the stock turbo. When I removed my turbo, exh manifold, I noticed alot of casting flash and metal boogers as well as some poor hot side housing casting. The O2 housing needs work too.
I did some porting on the hot side housing, specifically, there was ALOT of burs along the noozle opening, (which isn't a round or oval hole as you might think, It maintain the twin scroll through the housing and gradually blends into turbine).
The O2 housing is pretty poor too, lots of flash and it makes the exhaust turn some tight corners.
I also port matched everything.
DO NOT try to port match the exhaust manifold with the manifold gasket.
Its interesting you mention that.. I noticed the same thing.. One of my solutions was to get a Stainless header, Stainless O2 housing, JDM 9.8 Ti turbo, and the 10.5 hot side housing.. I'm sure even the 10.5 casting also needs to be cleaned up a bit.. but at least I'm not the only one who saw the crud..
yeah is sloppy in their castings.....I wonder what must be done to be able to port a twin scroll setup? Not a lot of room to work with....
These guys do good work. They are old DSM guys. http://www.slowboyracing.com/Intro.html
As far as what I noticed, The car was pretty stock at the time. I didn't feel alot at the time.
I'm doing the same thing MalibuJack is doing.
I'm trying to make the stock set-up as efficient as possible.
When I got my car Dynoflashed a couple months ago, Al said my car was the quickest 91 octane car he's tuned, with the exception of Robi's car, which was tuned within an inch of it's life.
With race gas, my stock turbo pushed 25psi only dropping to 21-22psi at 7850rpms.
I can't wait to get my head done.
I'm still not convinced the MAF sensor is restricting enough to justify the UR blow-thru or even more expensive, stand alone ECU with MAP set-up.
I'm sure when I start pushing 425+, the MAF will be a factor.
I also think the stock intake manifold is good.
Anybody else have any input?
