wont go into gear in a dead stop??
Old Jul 22, 2004 | 03:25 PM
fromgsx2evo8's Avatar
does anyone know what the problem might be? When i am at a dead stop i can't get the tranny into any gear. I think my tranny might be f-ed up. When it does go into gear it grinds.
Old Jul 22, 2004 | 03:40 PM
MalibuJack's Avatar
Does it go in easy when the car isn't running? If it does, then its possible your clutch is worn, or the clutch master/slave cyl has a problem.. If it doesnt when the car is not running, then it could be the selector assembly or fluid level.. In either case, I'd take it to the dealer and have them check it out.
Old Jul 22, 2004 | 03:49 PM
EvolvedDSM's Avatar
All of the above, but also check the pedal adjustment.
Old Jul 22, 2004 | 03:50 PM
SoR's Avatar
SoR
Shouldn't the pedal be self-adjusting?
Does this happen all the time or just sometimes?
Old Jul 25, 2004 | 03:46 PM
well the car is at turbo trix now getting the tranny done, i am excited!!
Old Jul 25, 2004 | 04:49 PM
MalibuJack's Avatar
I was curious to know what was actually wrong with it.. I had my selectors jam up (Couldn't get into gear at all, even when the car wasn't running) then after I had it towed to the dealer, it suddenly "Cleared up" I was convinced the dealer somehow didn't put enough lubricant into the tranny or it leaked out to the point it wasn't lubricating the selectors anymore after they did my 5th gear grind TSB..
Still doesn't feel the same as it did before.. But you chose the right place, I'm going to have them do my tranny when I have some liquid cash...
Old Jul 26, 2004 | 04:09 PM
not sure yet what was wrong i should hear by thursday. I just cant wait to get it back!!!!!
