Fuel pump
Old Jul 23, 2004 | 02:53 AM
dr zero's Avatar
Fuel pump
Need to replace fuel pump in 03 Evo VIII. What to choose? Stock or any aftermarket one? No plans for mods for the time being but who knows...
Old Jul 23, 2004 | 03:00 AM
Sentinal's Avatar
If your not planning on mods I would go with stock just to make sure Mitsu doesn't whine about warrentee stuff (which they shouldn't anyway) but just in case. Besides that you know that the stock one will fit fine not leak and will be reliable even if its not the highest performance. Not to mention its probably cheaper for ya
Old Jul 23, 2004 | 04:08 AM
dr zero's Avatar
Is Walbro pump any good? E.g.
http://www.myevostore.com/product_in...roducts_id=138
Old Jul 23, 2004 | 05:01 AM
TaiwanEvo's Avatar
I think you might run a little rich... someone correct me if i'm wrong
Old Jul 23, 2004 | 05:20 AM
tweakdsm's Avatar
walbro 255
Old Jul 23, 2004 | 05:33 AM
MrBonus's Avatar
Correct.
The Walbro will overrun the factory regulator a bit at WOT and you'll run a bit richer.
Old Jul 23, 2004 | 07:10 AM
dr zero's Avatar
So what should be done to compensate it?
Can I put in in place of stock pump without any other mods or should I not?
Old Jul 23, 2004 | 07:13 AM
Stinkapuss's Avatar
I wouldn't. Your going to run richer then you already are without any type of fuel management.
Old Jul 23, 2004 | 09:10 PM
IS2000's Avatar
I have the Walbro and the ecu was tuned for stock pump. Car is now running rich, and idles a little choppy.
Old Jul 23, 2004 | 10:39 PM
dr zero's Avatar
If I put Walbro 255, what should I do to make everything work all right?
How to use it's higher output?
Old Jul 23, 2004 | 10:43 PM
NOVA EVO's Avatar
You'll need to retune your air/fuel ratios with an SAFC or an ECU reflash...
Old Jul 23, 2004 | 10:57 PM
dr zero's Avatar
Will it itself give any increse of performance?
Old Jul 27, 2004 | 04:44 AM
chuntington101's Avatar
NO mate. it wont give you any more performance on its own. you will pronaly looes a little *** your engine will be running even richer than normal (reducing power). the stock pump is good for around 350bhp i think, and as other have said, it will fit and work straight out the box. there have been a few people that are not satisfied with the Walbros. some say they have packed up for no reason!
if you are planning on modding though, you may want to look at the SARD280 as well. a bit bigger and more exspensive, but i have heard they are more reliable!
thanks Chris.
Evodetailer123
Oct 6, 2016 01:09 PM
wallie123
Aug 10, 2016 11:53 AM
wallie123
Aug 4, 2016 06:53 PM
oscarquinones
E85 / Ethanol
Sep 2, 2013 12:28 PM
