problem with boost solenoid lines(diagram)
Old Jul 25, 2004 | 08:44 PM
MalibuJack's Avatar
I guess it all worked out.. And the reason it drops so low is the bleed rate is too fast with those restrictors missing.. Their calibrated to allow a specific amount of airflow through and minimize spiking so its no surprise at all.. You can buy a new hose assembly with the restrictors in it from Mitsubishi..
Old Jul 26, 2004 | 08:11 AM
darkjediii's Avatar
question: would it hurt to drive the car around while I wait for the part to arrive?
Old Jul 26, 2004 | 08:23 AM
MalibuJack's Avatar
Nah, too low boost means it'll run a little rich, and you'll be down on power, but it won't harm anything.
Old Aug 9, 2004 | 02:01 PM
KillaSweep's Avatar
I am having somewhat of a similar problem...my dealership just replaced the wastegate syllanoid because they thought it would fix some other issue....as soon as i got the car back i can only push 17psi max...the down to like 15 or so....could they have forgot to put something back in...or change a hose incorrectly to yield the resulted decrease in boost pressue? I am planning on getting an MBC until i can get the xede but want to make sure there isn;t somethign else wrong before i set a constant pressure of 19 psi.
