WHat do you think I will put down?
Old Aug 2, 2004 | 08:08 PM
Bobby12many's Avatar
Im fixing to dyno the evo next week, and just wondering what you guys would guesstimate I make.
Mods:
HKS RS Intake
Buschur 3" TUrbo Back (no cat)
Hallmann RX BC set to 21psi
Walbro FUel Pump
Dynoflash for mods.
Old Aug 2, 2004 | 08:10 PM
TD05HR's Avatar
around 300whp...thats what i got w. cept diff. brand names..and dynoflash..good shlt$.. to Al
Old Aug 2, 2004 | 08:11 PM
Originally Posted by TD05HR
around 300whp...thats what i got w. cept diff. brand names..and dynoflash..goos ****.. to Al
Nice.
Can the boost be raised beyond 20.5-21psi safely with my set up on 93 octane?
Old Aug 2, 2004 | 08:15 PM
TD05HR's Avatar
not really...theres no point in raising the boost higher..the turbo will run out of breath quick beyond that..plus u have to consider the safety margin..u also might need a fuel pump for those mods..i would recommend it b4 dyno tune..
Old Aug 2, 2004 | 08:16 PM
A walbro pump is installed.
Old Aug 2, 2004 | 08:17 PM
2004BlkEvo8's Avatar
It says in his first post he has a walbro fuel pump But either way, like he said, I wouldn't recommend going past 21psi.
Old Aug 2, 2004 | 08:43 PM
TD05HR's Avatar
oops..sorry i missed that..but yeah no more than 21psi
Old Aug 2, 2004 | 09:13 PM
@ 21 PSI am I reaching the ceiling of my injectors or the maximum efficient boost output of the turbine?
Old Aug 3, 2004 | 03:55 PM
TD05HR's Avatar
the turbine..the injectors are almost max out i think...but not there yet...w. the fuel pump u dont have to open the injectors as long...
Old Aug 3, 2004 | 04:04 PM
silverEVO8's Avatar
The blower will give more boost. The injectors are prolly maxed. I'm running 680cc injectors and I'm at 75% with them already making 250-280 hp (depending on the tune). That's at 19-20 psi. I know the blower will put out 23 psi, but I'm sure the stock injectors will max out long before that....
Old Aug 3, 2004 | 04:15 PM
THanks for the explinations guys.
SO to achieve any more powert with my setup, I would need cams/gears and higher flow injectors?
bishiboy's Avatar
Also, when you go above 21psi, you get out of the effcientcy window and the air begins to get hotter. Without a good intercooler set-up, you start losing power due to detonation and timing being pulled.
The stock turbo CAN push 25psi (dropping to 22 at 7800rpms), but not real good for it, overheats and shortens the life.
Old Aug 3, 2004 | 09:31 PM
silverEVO8's Avatar
I'm not sure about cams and cam gears, but certainly you'll need more fuel to make more power. Also, the intercooler might have to be upgraded. Generally, it seems that to make more power you gotta put more air and fuel through the engine. Of course, there are limits that you reach rather quickly and the engine will destroy itself due to overstress or detonation..... There just isn't any easy or cheap way to get more HP.....
Old Aug 3, 2004 | 10:52 PM
Thanks bro.
I am just looking for the most reliable and safe amount of power to generate without touching the head of the block.
I will most likely just get new Inj.s, a bigger FMIC, and an O2 housing installed and call it a day. The car is already wicked fast .
Old Aug 3, 2004 | 10:54 PM
SilverEvo8owner's Avatar
ii have about the same mods
today i made 310 at about 21 psi and 322 at 23 psi
296 at 17.5
the a/f ratios were about 10.7-11.2 at 6500
