Bigger Turbo
Old Aug 2, 2004 | 08:42 PM
dEdiYT11's Avatar
Bigger Turbo
I was wondering if any one was running an HKS turbo (like a 3240,TO4_) on their EVO 8. I was wondering what the spool up was. Using Nitrus, Stroker Kit?
Old Aug 2, 2004 | 08:52 PM
3240's Avatar
You're making 427whp on the mods listed in your signature?
If you search this forum you'll find a wealth of information answering all of your quesions.
Old Aug 2, 2004 | 09:13 PM
dEdiYT11's Avatar
Yep. im making that much HP with the listed mods. i did a search and found nothing.
Old Aug 2, 2004 | 09:21 PM
RENN-ART's Avatar
damn!! 427whp and 447lbs tq???????? why do u need a bigger turbo???
if u do get one, please send me your freak turbo!!
do u have a dyno for that pull? that's incredible!! that't not even with a standalone??? just UTEC?
Old Aug 2, 2004 | 09:22 PM
gofaster87's Avatar
Hmm thats some interesting numbers in relation of hp/tq, especially on a stock turbo. If you dont mind, could post your dyno sheets, I would just like to look at them for reference.
Old Aug 2, 2004 | 09:43 PM
dEdiYT11's Avatar
ill get the dyno sheets up ASAP!!!
Old Aug 2, 2004 | 09:46 PM
MalibuJack's Avatar
I suspect its either Crank HP (an estimate) or the SAE Correction for altitude is inflating the numbers a bit.. but as long as his run to run numbers are consistent, at least he can tell if new mods will make gains..
Old Aug 2, 2004 | 09:50 PM
statix's Avatar
No way in hell are those whp, must be flywheel.. Would definitely like to see that dyno sheet...
Old Aug 2, 2004 | 09:53 PM
dEdiYT11's Avatar
Dyno Sheet
Here you go
Old Aug 2, 2004 | 09:55 PM
3240's Avatar
Wow.
I'm impressed. It still doesn't seem possible considering the mods you're running. Oh well, congrats.
dEdiYT11's Avatar
its 426AWHP
Edit: At 27psi
Old Aug 2, 2004 | 09:57 PM
MalibuJack's Avatar
1.26 correction factor.. Normally only used for normally aspirated engines.. Look how early the HP and torque peaks, then dies off.. Definitely an overworked Turbocharger.. hehe.. Your numbers are closer to about 350whp (approx) for those mods..
What is your altitude? High altitude, warm day.. big correction factor..
Old Aug 2, 2004 | 09:59 PM
MalibuJack's Avatar
Have you gotten to a track yet?
Old Aug 2, 2004 | 10:00 PM
dEdiYT11's Avatar
Colorado= HIGH ALTITUDE
Old Aug 2, 2004 | 10:01 PM
MalibuJack's Avatar
You aint kidding.. I don't blame you for wanting a new turbo, at that altitude the stock turbo just has to work too hard..
