HKS EIDS install and help
Old Sep 8, 2004 | 09:09 PM
vletnguyen's Avatar
i have a question also. if i am running the utec. should i install the eids as if i am running with no piggyback? i thought it had to be at the end of the chain. can someone clarify?
btw i order mine through a local shop. for 115. they ship also.
the contact info
Randy Diaz
Racing Zone Auto House of Tampa
Tel813)873-2235
Fax813)873-8935
www.racingzoneautohouse.com
tell him jimmy with the silver evo sent you.
Old Sep 9, 2004 | 12:14 AM
trinydex's Avatar
it's prolly when the stock bov starts to leak and all that air goes out into the atmosphere and you start drowning yer plugs. i wouldn't recommend running vta with something that leaks so easily. but you'd just have to take that tube off, that's all. get a type s from rre and try that setup, it seals pretty well... and releases pretty well too because it's pnuematically assisted.
Old Jan 14, 2005 | 01:30 PM
jaredk7448's Avatar
hks eids problems
I have a 2005 evo 8 rs with aem short ram intake and greddy type s bov.
I am running it VTA. So i went and got a hks Electronic Idle Stabalizer. I have every thing hooked up correct. But when i plug up the eids and crankt he car the service engine light comes on. But if i unplug the eids and plug up the loop and unhook the battery to reset the ecu the light goes off. it only comes on when i hook up the eids does anyone elses do that is it normal. Thanks Jared
Old Feb 16, 2005 | 01:50 PM
honki24's Avatar
from what I've read, you've got your wires backwards
