Knocking engine sound?
Old Aug 6, 2004 | 06:35 AM
plokivos's Avatar
Ok, I need to be completely sure about what the knocking sound sounds like.
I was idling this morning and I heard the engine pulsate but it was a lot rougher than usual.
It would pulsate then it made a sound like it's trying to suck in air, but very deep.
Almost like if someone was punching a foam covered bag... sorta muffled.
I know the knocking sound is a lot more sharper than this, but I just want to make sure.
Anyone got a sound clip of knocking?
Thanks.
Old Aug 6, 2004 | 09:08 AM
Secret Chimp's Avatar
Tech questions belong in the tech forum.
Moving to the Engine/turbo/drivetrain forum.
Old Aug 6, 2004 | 09:10 AM
alex_alex's Avatar
i was curious about this as well.
Old Aug 6, 2004 | 09:13 AM
MalibuJack's Avatar
How many miles are on the car? It could be the PCV valve making noise..
Old Aug 6, 2004 | 12:16 PM
plokivos's Avatar
20,100 miles. I don't know. It just got me worried, since the sound happened continuously, one after another.
Old Aug 6, 2004 | 01:14 PM
Thoe99's Avatar
I think that's normal, mine's always done that, stock.
Old Aug 6, 2004 | 03:18 PM
Funky's Avatar
The sound of "knock" or "ping" is very similar to what it sounds like if you take 2 plastic Bic pens and tapped them against eachother. But a bit more metallic in practice, it's very close to the sound though, and you should be able to recognize it. It is unlikely that you would get ping at idle under vacuum.
Did it happen shortly after you started your car? Have you checked your oil level recently? How about the coolant level? I've heard all kinds of weird noises come from cars when the coolant level dropped a bit, although never to the point of overheating.
Old Aug 6, 2004 | 09:58 PM
wangspeed's Avatar
Sounds kinda like marbles in a can.
Warren
Old Aug 6, 2004 | 10:01 PM
EvoJimbo's Avatar
taht doesnt sound too good. Could be a spun rod bearing????:shrug: did you chcek your oil levels?
Old Aug 7, 2004 | 08:35 AM
BLiu's Avatar
Warren
Yes, that's the dreaded sound of engine detonation...
Brent
Old May 29, 2025 | 12:12 PM
Tplancerevo9's Avatar
Thanks.
could be normal
