1.23 bar = 17.8 psi am I low on boost ?
don't forget your boost solenoid reads before the IC and pipes... you TT is most likely reading off the manifold... so you will have some pressure drop to calculate for; i would believe 17.8 psi is stock and fine... the 19/16.24 psi's are what the boost solenoid opperate at and are taken prior to the IC, as just stated...
Originally Posted by apexeight
Is 1.23 the highest you saw? It does sound a little low. My blitz usually shows 1.33-.35 and has shown 1.38 before.
I have a DTT DCII from Blitz and tonight it peak to 1.32 bar and it tapers to 1.21 something like that and yes I am totally stock . So I think thats normal .
Thanks guys for your reply .
i got an autometer boost gauge and my boost hits 21psi. but my dynoflash is set at 19.5
what the heck is up with my boost gauge? is this a bad install? and what gauges do you guys have to read bar?
do u guys think its possible im actually running 21psi?
Originally Posted by 1QWKEVO
are u stock or do u ahve bolt ons? also when looking at boost you should only be concidering holding psi not spikes plus with colder weather you will see higher boost levels and if your running 91 octane theres another problem... theres many factors that will affect boost specially on MAP sensor cars
Mostly stock (for the next 5 days
)I agree - my numbers were peak numbers, not consistent. I thought his concern was peaking at 1.2 (trying to compare apples to apples). I think the mid to high 1.2s is normal for a consistent reading.
My buddy has an Autometer boost gauge in his stock Sti and it reads 20 psi.
Now we all know that Sti's can't boost over 16.5 without some fuel controller or larger injectors.
I guess the gauge is wrong.
