Does anyone make more solid motor mounts?
Old Aug 8, 2004 | 04:59 PM
bolsen's Avatar
I'm looking for a more solid of motor mounts, if anything just for a better feel of the motor and car. Does anyone make them?
Old Aug 8, 2004 | 06:17 PM
Zeus's Avatar
I'd like an affordable set to take out the drive lash... I'm thinking of installing the ES kit, but there are not engine mounts in that kit.
Old Aug 8, 2004 | 08:27 PM
Crazy4Cars's Avatar
Ralliart does.
Old Aug 8, 2004 | 09:31 PM
bolsen's Avatar
Originally Posted by Crazy4Cars
Ralliart does.
Can you recommend a reputable purchase place?
I'm googleing but there and there are places to buy, but none I've heard of.
Old Aug 8, 2004 | 10:50 PM
bryans2k's Avatar
I'm actually going the window weld way... to make my own custom filled stock mounts...
bryan
Old Aug 9, 2004 | 12:35 AM
value's Avatar
Seen them from Deck Mechanical, Bozz Speed make them + they have them for the Diff also.
Old Aug 9, 2004 | 06:46 AM
propellerhead's Avatar
bryan
Do you have any more details or a post you can point us to?
I have an idea that some of the gear crunching I get in 2nd and 4th is due to drivetrain shifting around under certain load directions. I seem to only get a grind in those two gears while under hard acceleration around right hand turns. This usually happenes to me at the track going into 4th. It's entirely possible that my shifting gets sloppy due to the lateral cornering forces. But I'd like to eliminate the possibility of the transaxle sliding around.
Old Aug 9, 2004 | 07:57 AM
4ce fed's Avatar
Here you go: http://www.dsmtalk.com/forums/showth...ht=window+weld
Basically buy the windo weld and fill in the gaps on the stock motor mounts. I did this to my Eclipse, and it was worth it.
Old Aug 9, 2004 | 10:01 AM
bolsen's Avatar
Hmmm, I think I'd like to buy poly mounts if I could.
Does anyone know if the Evo mounts are the same as say a 2g? Cause I found mounts for a 2g, and if the mounts are the same, I think they'd be interchangable
Old Aug 9, 2004 | 11:00 AM
4ce fed's Avatar
Sorry, I was responding to propellerhead, since he asked about the windo weld. It does work, though. If you can't find any motor mounts, this is a good solution.
Old Aug 9, 2004 | 12:00 PM
EVOTEXAS's Avatar
I would also like a viable and CLEAN solution.
Old Aug 10, 2004 | 10:50 AM
bolsen's Avatar
up
Old Aug 10, 2004 | 10:52 AM
VTECH8TR's Avatar
I have done this to several DSM's and this method works wonders.
Old Aug 11, 2004 | 07:29 AM
bolsen's Avatar
Up up and away!
Old Oct 31, 2004 | 01:09 PM
machron1's Avatar
Anyone know where to get the Ralliart motor mounts? I would like a nice clean set of polyurethane mounts/inserts. I'm not too hot on the window goop solution. I had some nice mounts for my DSM that worked wonders, although the ensuing felt vibrations in the cab were sort of annoying.
