Help me diagnose this problem
Ok changed my clutch at 21K with Exedy Hyper Single. Got mistu to install it but they obviously messed something up.
When I first got the car the clutch would engage About 1/4 up from floor. Then after half a day of driving it started engaging higher and higher. Now it's all the way up top. I mean last 1/10th up top. I tried to change the pedal adjustment but that only changes if up top is closer to the floor or not. Still doesn't solve my issue. I think I might have to bleed my clutch line. Forgot to say I had them install a SS clutch line. I dont think they bled the system properly.
Another symptom happens when I slowly and carefully disingage the clutch at start and leave the rpms around 1.5 k the clutch grinds quite a bit. It's not smooth but clunky.
Also i now have much lowder transmission noise on decel at 3K but I think that's normal.
What do you guys think? I don't want to take it back to mistu. They will just tell me that it's the aftermarket clutch fault. Do you think they could have miss installed it? or is that impossible.
well i think if they were willing to install it in the first place, would they give you a problem about it if you brought it back?
if they do thats horrible. but i dont see why they would,.... but this is mitsu we're talking about...
