should i put it on or not?
Old Aug 11, 2004 | 09:14 PM
EVO8HKS's Avatar
ok, i have hks dp and 30th on the car. been searching, reading people stating the rs kit makes the car loss boost. but i just got the kit before reading this. should i put the whole thing on or should i wait for a flash or utec before putting on the filter and just putting the Suction Pipe on now. i just put on the dp and love how its running w/ the 30th and dont want to lose it. any help or thoughts are appreciated, jon
Old Aug 11, 2004 | 09:23 PM
differentstroke's Avatar
I'd wait the RS intake make the car run lean and a warblo 255 fuel pump and and reflash and you'll be straight also consider a boost controller man./elec. your choice
man. - cheap and does the job
elec. - expensive but can change the boost from inside the car cant w/ a man.
you should get around 300whp to the wheel with this setup
Old Aug 11, 2004 | 09:29 PM
EVO8HKS's Avatar
well if i get the utec, i wont need a bc. right?
Old Aug 11, 2004 | 09:46 PM
umiami80's Avatar
You need to tune with an intake. If you just put on a intake with nothing else. The car interprets it as a problem and lowers timing, makes the car feel sluggish, if you tune with an HKS RS intake, it will probably be the best as it certainly flows the best based on its filter, but high maintenance on that filter. I hae one, I like it but it needs to be tuned.
Old Aug 11, 2004 | 09:57 PM
the UTEC has a built in bc but...... most people withit use a bc for saftey purposes a bc is build for boost the uTEC uses the stock bc and we all know that the stock bc and bov suck
Old Aug 11, 2004 | 10:04 PM
EVO8HKS's Avatar
my friends wrx utec came w/ manual bc. the evo utec doesnt come w/ one.
Old Aug 12, 2004 | 08:52 AM
EVO8HKS's Avatar
or should i use utec + bc?
