Why is my car so slow?
Old Aug 16, 2004 | 01:10 AM
2004EVORS's Avatar
Are you using 87 octane gas?
Speed of shifts, shift points
Work on launching the car, preferably 4K to 5K consistently.
You need some practice. I think you can benefit from using opportunities to find a empty lot an try launching in it. I had two years of practice with AWD and am now consitent.
Old Aug 16, 2004 | 01:25 AM
MagEvoVII's Avatar
Originally Posted by Jadiem
it's not the clutch... no fuel regulator..
Not saying this is the reason for your problems, but with your list of mods, you should have a regulator to enable you to control the fuel pressure.
I agree with 3000, just didn't want to say it. Could be a combo between tuning the car and learning how to launch it. Just keep working at it, the only thing we were born knowing how to do was crap ourselves, pee, and cry for food...
good luck sorting it out.
Old Aug 16, 2004 | 04:15 AM
Jadiem's Avatar
Originally Posted by EVIL VIII
Maybe having Travis (if that's who you are reffering to) not touching a 4G63 when he blows up QR25 motors will help...but if it is not Travis, then disregard what I am saying because I am a moron...but if I am correct...TAKE THE CAR FAR, FAR AWAY FROM HIM!!
wow, i didn't know he was that popular... i went ahead and cleared my E-Manage and def notice the extra fuel... i'm gonna leave it like it is until i get it tuned.. it feels like i'm launching the car right and i've been around the drag strip quite a bit...
Old Aug 16, 2004 | 08:34 AM
bolsen's Avatar
Oh did I mention tuning is everything?
Old Aug 16, 2004 | 08:42 AM
evomind's Avatar
theres nothing wrong with ur car.....60ft times of 2.0 in an AWD car is kinda sub par....you should be able to hit 1.70 consistently....every tenth of a second u shave off ur 60ft time is like i think .2 seconds off your time for the quarter....(cant remember exactly, i know its either .2 or more though.)
so if u run 1.7 60 ft time ur time would have been like 12.9....
now if u ran 12.9's maybe u wouldnt be thinking theres a problem with the car, right?
Old Aug 16, 2004 | 09:59 AM
Jadiem's Avatar
if my car was running 12.9s, i would still dyno tune it because i'm still curious to see how much hp i have and how i could possibly increase it by a dyno tune
Old Aug 16, 2004 | 10:08 AM
jason@NTEC's Avatar
yea thatas not right, one of our members has
-3inch turbo back exhaust
-mbc(set for 21psi)
-hks rs intake
-turbo trix flash
he ran a 12.8 in ennis, tx on friday night
he also dynoed 292 at the wheels yesterday on a mustang awd dyno
Old Aug 16, 2004 | 10:21 AM
Z1 Performance's Avatar
lack of tuning seems to be your culprit
I would try subscribing to the Yahoogroups list for the E Manage...there are some very competant users there, and I am sure they can help point you to someone in your area who can properly tune it for you
Old Aug 16, 2004 | 10:34 AM
Jadiem's Avatar
well, i'm bring the car to New Orleans to get it tuned with a wideband this week... it's the closest i can get to a real tune witout driving 6+ hours to Houston....
also have the HKS SS bov coming
Old Aug 16, 2004 | 02:03 PM
k270kmh's Avatar
I'm not a tech but I guess that you should give a try to:
Put stock plugs back and see
Maybe the 255l walbro is too much for you
I don't know about magnecor wires, but when I put MSD SCW in my LT1 my car ran like a sht.
For sure you need to tune your car.
Old Aug 16, 2004 | 02:16 PM
marksae's Avatar
I would bet that the Walbro is over-running the stock fuel pressure regulator. This will throw your fuel trims off inside the ECU. With a big fuel pump like that, you really need a fuel pressure gauge to monitor what's going on. With an adjustable FPR, you'll be able to dial your fuel pressure back to stock to get your car to run right. Like Bolsen mentioned earlier, tuning is everything.
Old Aug 16, 2004 | 02:48 PM
Jadiem's Avatar
i have a Fuel Pressure Gauge, and at idle it's right at 2.5-2.75 bar... it goes pretty high once i put a load and get into boost... i'll get exact measurements later...
anyone have a FPR in stock?
edit: Fuel PSI gets up to 4.75 bar under full boost
Old Aug 17, 2004 | 08:59 AM
Jadiem's Avatar
what should my AF ratios be? 11:1? 11.?:1?
Old Aug 17, 2004 | 09:30 AM
in the 11.0 range yes, but you also need to be looking at ignition timing via the logger to ensure your car is advancing all it should and not dinging it downward uncessarily due to knock
your fuel pressure is fine at idle...telling me the pump is not overtaxing the regulator. However, based on what you are saying, you are running roughly 27 psi of boost?
Old Aug 17, 2004 | 11:22 AM
Jadiem's Avatar
i'm running 21 psi... thanx for the info z1!!
when i say 4.75 bar, i mean thats the highest it gets when i'm under full boost/load...
