Car stalled and won't restart
hey i'm having the same problem and after scanning the ECU i found out i have a faulty crank angle sensor. when this fails, the ecu shuts down the ignition which is what happened to me and it sounds like the same thing happened to you. I posted a thread about it today as well. The only thing is, people posted pics of the CAM angle sensor when i meant CRANK angle sensor, and teh crank one is a ***** to get to. The cam angle sensor is located on the front of your block.
check it out, it might be that sensor
Yeah.. It could be either.. I posted it in another thread, but either sensor failing would likely result in a no-start condition.. a problem with the MAF sensor (Baro sensor for example) would result in the car "kicking over" but not running.. but bad MAF output frequency might result in a no-start also especially if the frequency is 0..
delongedoug
May 21, 2010 04:20 PM
babyboba29
Lancer Engine Tech
40
Mar 16, 2004 09:57 PM
as we speak
