RS front LSD interchangable?
Originally Posted by JustDSM
Funny you say that. I've FITTED the RS transfer case to my car. I'm not informed/educated enough on the subject, but others (with SAE certs) tell me there might be an issue. Thats not saying there will be a problem. I decided to hold off and do the research before I plunked my credit card down.
actually that is funny. so, did your original axles work with the RS transfer case?
I can't see there being a issue with ABS and a limited slip diff. And if there is just pull the fuse. The guys that rally Subarus use this extention with a on off witch for ABS.
Eric
Eric
That is the proper part number according to CAPS's latest release. Last time I had the dealer look the part up (for a price check) their system did not have the part listed yet. It's still very new. Unless something changes in the next month, that will be the part number.
ColinL: Did I say they did? I didn't attempt to fit them, but the part numbers indicate it would fit. Anything else superguru?
Isn't a evo 5 front lsd a helical type aswell? If it is, the 04 rs front lsd should work in a 03. There is a guy on here with a evo 5 front lsd with ABS on his 03 and he said it work with no issues.
Why do the rs when this is coming soon?
https://www.evolutionm.net/forums/sh...ghlight=quaife
1) Quaife has lifetime warranty- including racing vs. RS in a non RS evo= no warranty....
2) Cost- the Quaife will list at $1345 vs. having to buy a whole transfercase = over a grand more expensive for a part.
