new cams without new rocker arms?
Old Jan 24, 2013 | 08:36 AM
BogusSVO's Avatar
You may have dinged a couple valves.
Broken rockers...ok
What cams, and what spring package do you have installed.
It sounds like you have more cam lift than the springs can handle, causing the springs to bind, when this happens, something has to give.
Old Jan 24, 2013 | 09:08 AM
kevin8086's Avatar
Coss m2 with ferrera double springs
Old Jan 24, 2013 | 09:11 AM
kevin8086's Avatar
The springs should be more then adequate for those cams. Is it possible the rockers weren't seated properly?
Old Jan 24, 2013 | 09:26 AM
talonkev's Avatar
Did you bleed your lifters before putting it back together?
Old Jan 24, 2013 | 09:44 AM
BogusSVO's Avatar
The cams are 11mm lift, and the duals are rated for 12.5mm lift, so that should be good, unless the were installed with an extra .060 spring shim.
Old Jan 24, 2013 | 11:52 AM
kevin8086's Avatar
Ya. I bled all the lifters. Not sure about shims. Just installed what was there. There were some rubber type washers on the bottom
Old Jan 24, 2013 | 11:58 AM
kevin8086's Avatar
This is everything installed
http://realstreetperformance.com/sto...ivec-2438.html
Old Jan 24, 2013 | 12:00 PM
kevin8086's Avatar
Oops. That not the dual but I have the dual and those retainers and seats. That's all that was installed
Old Jan 24, 2013 | 12:26 PM
BogusSVO's Avatar
Did you leave the factory spring seats in place, and stack the Ferrea seats on top?
Old Jan 24, 2013 | 01:35 PM
kevin8086's Avatar
Do the factory springs have rubber seats? I don't see them anywhere
Old Jan 24, 2013 | 01:40 PM
kevin8086's Avatar
Does factory have Spring seat locators?
Old Jan 24, 2013 | 01:50 PM
BogusSVO's Avatar
No they should be a shim, about .040 thick, looks like a bolt washer sorts.
Rubber spring seat????? The valve stem seal has a bit of rubber. You should have what is called a metal clad style. The part of the seal on the guide is metal, then rubber surrounds the valve stem.
There is a Top hat style, it is a metal clad seal with the spring seat made on to it. (3.1 GM V6 uses this style, so does the 420A Chrysler/Mitsu)
Old Jan 24, 2013 | 02:08 PM
kevin8086's Avatar
Umm crap. Idk. I pulled the springs with the top retainers and put in the new springs seats and retainers. Do u have a pic if what else I should have removed? Can u text me instead of being on here? 817-773-6881
I appreciate ur help
None of the how to say anything about removing anything but the spring, retainers and keepers.
Old Jan 24, 2013 | 02:15 PM
kevin8086's Avatar
So that metal washer was supp to come out?
Old Jan 24, 2013 | 02:22 PM
kevin8086's Avatar
Ok not rubber. It's black steel seats. So the stock ones were supp to come out. Damn. My first time doing this. I read all the how to and nothing mentioned this
