Had Hallman Pro MBC Installed
Old Aug 28, 2004 | 03:33 PM
heevo's Avatar
I had my mbc installed at Super Autobac's in Stanton, CA. They installed it inside my car by my right leg. It's not in the way and I like it there but wasn't it supposed to be installed in the engine bay. I know there is another Hall pro with a kit that can be adjusted from the inside, but this one is not it. I trying to find out if I should have it reinstall in the engine bay because I was told by some else thet the hose's on the boost controller were supposed to be as short as possible. Any tips or advice would be appreciated.
Old Aug 28, 2004 | 04:37 PM
EVOTEXAS's Avatar
You're right. Lines should be as short as possible. That's a bad install.
Old Aug 28, 2004 | 04:51 PM
sleet's Avatar
What's the difference if they are longer or not? Mine have some slack incase I wanna move them, if this is bad or somthing then lemme know so I can trim em down.
Old Aug 28, 2004 | 05:37 PM
NOVA EVO's Avatar
WTF??? It should be in the engine bay!!!
Old Aug 28, 2004 | 05:55 PM
DocMortal's Avatar
Thats weird bro...they must of made that line really long and will decrease the MBC boost response...
I had my car aligned there,they seem pretty good,my hose is less then 2 feet right under the intake snorkal...its the perfect spot...
A MBC install is super easy,you could have done in in 30 minutes save some dough...
No big deal but it should be in the engine bay....
Old Aug 28, 2004 | 08:50 PM
sleet's Avatar
So should I make my lines shorter or not or it really gonna matter??
Old Aug 28, 2004 | 09:08 PM
AWDTurbo4's Avatar
bump
Old Aug 28, 2004 | 10:28 PM
DocMortal's Avatar
make it shorter,in the engine bay... even in my hallman instructions its says to not make the line long...
thats why hallman makes a wire adjustment connector for inside the car instead of long tubing
Old Aug 29, 2004 | 08:34 AM
heevo's Avatar
hallman
Thanks for the info. I guess I'll have it relocate into the engine bay. I haven't had any problems with it yet. It's holding boost but I won't risk it. thanks again.
Old Aug 29, 2004 | 08:38 AM
tweakdsm's Avatar
thats right, mine is in engine bay, i mounted by air K&N cone, with screw.
