Ultimate Racings Turbo.
Old Aug 29, 2004 | 04:16 PM
Nesiop's Avatar
Finally got it done after modify after modify with the turbo kit, didn't know you needed all there supporting mods to make it bolt on. Buschurs front mount needs a little mod to work with there intercooler pipes so that you don't have to cut the dump tube later, Need upper intercooler pipe with BOV relocated up there so it isn't so tight etc.... But all in all it is a great kit.
One question though... I need it tuned but so I can drive it and not worry about hitting boost I need to close my boost controller. I had problems with Ultimates turbosmart one where the screw got stripped, so they put a long screw in it to adjust it. But it got stripped, but I can close the bc all the way. I think though it is broken cause closed all the way I go to test it, I hear the scream of the wastegate but hit 20+ pounds of boost. One end goes into the HKS WG and one end into the turbo... Tried both ways. arrow say such" End with arrow goes to wastegate actuator. Put that in and it sitll is open, figured maybe the new actuator is on the turbo tried that still wide open. Did I set that part up wrong or is the BC broken?
Need answer really fast so someone please call.
774-406-0172
Tim
