tranny mounts?
tranny mounts?
where can i get some stronger trans mounts, dont know if i need ethem or if they werent put on right in the first place, i had some clunky sounds under the car
so i put it on the lift and put it in first gear and had my friend just tap the gas real quick with the clutch released and the whole tranny moves back and forth like 4-6 inches. so i assume its that. ne one else have this issue?
Zeus sorry I was just trying to get EVO8 WHOA's attention because he had requested some info on a battery & tray combo I was offering, nothing related to the tranny mounts, just looked for his most recent post.
Originally Posted by value
Deck Mechanical Power has both tranny and engine mounts.
Jesus, where were you a few weeks ago when I asked like 30 questions on the subject?!
I am certainly going to look into this... I'll let yall know what I find.
here's the babelfish translation of the site
>Driveand mount type >pyroengine mount of classified by TOP >WEB catalog part
Pyro engine mount
On the photograph FD3S and under are for SW20.
It is only-too-natural thing, but the engine is loaded onto the machine, the mount is necessary. And in the normal car the rubber is used from the thought for sound and the vibration. But, when sport travelling is done, the engine shakes with the flexion of the rubber. Traction escapes, down of the accelerator pickup, as for being worst the trouble where the gear does not enter occurs.
Simply, of travelling efficiency should have been thought, if is, it meaning that the rigid mount which is similar to the racing car is most, it does, but just, noise of the racing car beam the vibration wraps the cockpit,. Then, in the deck we had decided to use the pyro ball of teflon liner enclosure type for the buffer agent of the mount. With this, the vibration and noise being able to decrease it is rather. With run sir evolution and the like, above exchanging to the mount of the strengthening rubber, while showing shaking prevention efficiency, as for noise you hold down below the strengthening rubber.
But, development had a rough going other than. Largest key point was pyro size decision. If size is small, increases with abnormal play directly when and, it is large, price becomes high. While making such a, prototype mainly, if this the size that was found, it is not problem, perfection was expected in the product and "1 size big ones use" were done from that size.
In addition, because the private tool and large-sized press become necessary, DIY job unless from the first it is professional shop, can call to doing pressing in job the large aperture the EVO series, in regard to MR2, the engine mount bush that installing is difficult. Then, it produced from the stay part of the mount and made unit exchange possible. Because of this, exchange only of the hand tool became possible.
After the エボ 7 anterior is unit exchange type, but the engine mount exchange load of rear side being attached, because removal and re-installation of the sub frame becomes necessary, as for convenience of unit fixing type that it is not, it judges and has made pressing in type. When it is the usual street, the effect is shown sufficiently with anterior only exchange. In addition, if SW20 when bulkhead side is exchanged, is street subject because the vibration penetrates rather, exchange only of rear side is recommendation.
In addition, as for the transverse engine like EVO and MR2 the engine shakes mainly on front and back. Because of that, by the fact that locking the inside front and back direction of the mount which is 4 places, low measure and the effect of cost and the vibration and sound can be compatible it is.
Pyro engine mount
tranny mounts from Deck
>Driveand mounts >リジットデファレンシャルマウントof classified by TOP > WEB catalogpart
リジットデファレンシャルマウント
The photograph for FD3S in addition clicking the picture item name!
It is only-too-natural thing, but the diff. is loaded onto the machine, the mount is necessary. And in the normal car the rubber is used from the thought for sound and the vibration. But, when sport travelling is done, the diff. case shakes with the flexion of the rubber. Traction escapes, causes the down of the accelerator pickup.
It is possible to shut out the shaking of the diff. altogether by the fact that it mounts same as the racing car rigidly.
By the fact that rigidity it does, it to reach the point where the movement which is input from the propeller shaft is transmitted to the drive shaft to direct, after (the rubber finishing to tilt once in direction of rotation rotation direction, power it is transmitted) linear due to accelerator on off drive transmission becomes possible.
However, as for noise and the vibration being to become large please note.
リジットデファレンシャルマウント
yeah you gotta love the broken english translations of babelfish, looks like they offer metal"rigid" and poly"pyro" mounts for both engine and tranny applications. Pricing according to xe.com and Deck's pricing including tax the diff mount for the RS, more of what we would need I would assume considering the GSR has the electronic controlled diff which could have different mounting points, comes out to 229.612 USD and 411.531 USD for the motor mounts. WOW. Some one should call energy suspension and see what they have on the plate.
