What size is the stock Exhaust?
I just replaced the factory cat back exhaust with a HKS. I want to get the helix hi flow cat and the downpipe. I know the hks is 120mm but is it that too at the cat/exhaust connection. Thanks
I had a similar question.
Hope this helps.
Aug 30, 2004, 07:08 PM #9
Quote:
Originally Posted by GreedMOTO
Is this a direct cat replacement? I have the HKS dp and Carbon TI. Will it bolt up/ line up?
Do I still need the O2 simulater to avoid the CEL?
Yes direct cat replacement. Will bolt up and line up fine w/ HKS DP and Carbon Ti. All the mounting hardwares and 3" gaskets are included.
No need for simulator. Will not throw a CEL>
Thanks!
__________________
Gruppe-S Engineering LLC.
29150 Simms Ct.
Hayward, CA 94544
510)783-5300
510)783-4300 fax
Hope this helps.
Thanks!
__________________
29150 Simms Ct.
Hayward, CA 94544
510)783-5300
510)783-4300 fax
