Toda Stroker engines 2.32 liters available.
Old Sep 9, 2004 | 06:18 AM
David Buschur's Avatar
Hi all,
Tons of interest in the stroker engines for the EVO8. So much so that I went ahead and put one together and have it on the stand and ready to ship.
I don't see a problem with doing these in the future on a regular basis.
I used the Toda Stroker kit as it was priced right and available.
The kit uses a 2.4 liter crank, a set of production Mitsubishi rods and a set of nice forged coated pistons.
The kit retails for $3500 by itself. You then have to do the machine work to the block, supply main bearings, main studs, balance shaft elimination kit and assemble it.
I have the completed stroker shortblock for $3500. I do need your core back after you get the engine in and in your car. I will also sell them outright for $4,000.
Take care,
David Buschur
www.buschurracing.com
Old Sep 9, 2004 | 06:26 AM
MalibuJack's Avatar
I'll have to call you later, I have a core head and a core short block (Hopefully showing in the next few days) probably interested in a package deal but I'll talk to you about this offline or in PM's..
Old Sep 9, 2004 | 06:33 AM
We have a spare head here too, I think we have two at this point we are using to swap out for installs here at the shop. Give us a call.
David Buschur
Old Sep 9, 2004 | 06:35 AM
newevo8's Avatar
4,000 put together. What is the ball park figure to have you install?
Can you please expain the positive/negative compromise with this setup? Do you recommend something other than the stock turbo?
thank you,
Old Sep 9, 2004 | 07:34 AM
rraulston's Avatar
i read in a magazine article awhile back that this kit needed the pistons machined for clearance or somthing. Is this the case?? Also i hear you guys like the Eagle stuff, are they doing a kit also??? Are the stock rods adequate??? RRR
Old Sep 9, 2004 | 07:39 AM
Rez90's Avatar
Does anyone have one of these installed? anyone know about the longevity of this engine and what HP levels it can produce with different turbos?
Old Sep 9, 2004 | 08:06 AM
value's Avatar
Unhappy
Sorry but for that much $$ and only get rods I'd look somewhere else. Check out Deck Mechanical or if you have extra bucks Tomei.
Old Sep 9, 2004 | 08:32 AM
MalibuJack's Avatar
I was actually also interested in using the eagle kit if possible.. But I'll call you guys early next week, I want to make sure the core short-block makes it here without any problems before I start planning or laying out cash.
FWIW $4000 outright would make the block around $500 and thats a better price than I paid for my core short block.. and better than the going rate for them..
Old Sep 9, 2004 | 08:47 AM
bryans2k's Avatar
would you be able to use this kit on the stock ecu? curious...
bryan
Old Sep 9, 2004 | 08:50 AM
bryans2k's Avatar
The stock mitsu rods can handle a good amount of power. It's only the pistons that can't.
I say it's a good price.
bryan
Old Sep 9, 2004 | 12:55 PM
value's Avatar
Yes they can, but if you are going to all the trouble and expense why not make it bulletproof.
Old Sep 9, 2004 | 02:45 PM
metaphysical's Avatar
Registered User
Because bullet-proof costs money. This is $3500 bucks built, how much is the JDM stuff your quoting? And if you want to run a 2.3L daily driver and you don't plan on running C16 and 30PSI, why spend the extra?
Old Sep 9, 2004 | 03:15 PM
value's Avatar
Deck's kit which runs $3545 !
Old Sep 9, 2004 | 04:35 PM
JustDSM's Avatar
And then machine work...
Old Sep 9, 2004 | 08:40 PM
bryans2k's Avatar
Add in $500-600 for the block work and don't forget the extra downtime from not having a core for them to work on. Oh, also think about the quality of work of the shop you take it to since Buschur has a lot of experince on the 4g63 you would be taking a chance at an average shop that maybe doesn't care about you returning to them.
bryan
