EGT probe location with stainless manifold
Old Sep 12, 2004 | 11:40 AM
Wizard_of_Evo's Avatar
I am going to install either a dnp or ssautochrome manifold. my question is, for those of you that have done this, where are you placing the egt probe. i have my probe located in the #2 runner on my stock manifold.
thanks
Old Sep 12, 2004 | 11:52 AM
EVIL VIII's Avatar
I had my downpipe tapped and installed the probe there. I was a bit concerned about putting the probe in the exhaust manifold or the number 3 cylinder. If the probe breaks (highly unlikely, but has happened), if it's at teh downpipe, it will just shoot out the muffler. Think about where it may go if you tap the manifold or #3 cylinder....EEK!!
Old Sep 12, 2004 | 12:08 PM
that is what i thought i would do. what temp readings are you seeing that far down?
Old Sep 12, 2004 | 12:21 PM
ATOS_152's Avatar
EVIL VIII do you have any pics? what type of downpipe do you have?
Old Sep 12, 2004 | 01:46 PM
EvolvedfromaWRX's Avatar
isnt that not accurate if its in the downpipe? cause it would technically be cooler there?
Old Sep 12, 2004 | 01:54 PM
well you could still tell if things were running abnormally hot under prolonged high boost. plus in my case, where i have had it in the manifold i could quickly compare the new readings to the old ones. thus getting an accurate baseline for future comparison.
Old Sep 12, 2004 | 01:59 PM
bolsen's Avatar
I believe you are supposed to put it in the leanest runner... meaning furthest from the intake path. (cyl 1?)
I wouldn't put it in the dp (tho I know you can) if you are lookig for absolute #'s.
Old Sep 12, 2004 | 02:15 PM
i just really dont wanna tap or weld on the stainless
