Would this cover repairs?
Old Sep 14, 2004 | 09:15 AM
ruthless evo 8's Avatar
Question Would this cover repairs?
It is turning out that My engine is screwed needing new pistons, bearings, crank, rods, and rings.
Besides going with OEM parts would a stroker kit replace most of these parts?
what additional work is needed with installing a stroker kit?
I figure if the total price for the repairs is close to what it would cost to put in a stroker kit then why not right?
Old Sep 14, 2004 | 10:08 AM
no one have anything to say about this?
Old Sep 14, 2004 | 10:40 AM
MalibuJack's Avatar
Yes.. a stroker kit typically has those components.. You will also likely have to replace your Cams, cam bearings (if you digested metal) and the balance shaft bearings (or use a balance shaft eliminator kit) and oil pump.. Everything else should have survived as long as the block itself didn't take any damage..
Old Sep 14, 2004 | 11:11 AM
well just got back from mitsu and yes the block did receive damage so i need a new short block. damnit
Old Sep 14, 2004 | 11:44 AM
LateSleeper's Avatar
What happened to your engine? Were you running any mods?
Old Sep 14, 2004 | 01:57 PM
thrown rod and bottom end damage. i had a 3" turboback with cat delete pipe, hks rs intake and greddy profec b boost controller. the cause was probably over boost.
03BoostedVIII
Sep 25, 2010 04:31 AM
benderrodriguez
13
May 27, 2010 03:56 AM
spooledevo
Jun 20, 2006 07:29 PM
Evolution4g63
Jun 15, 2005 07:51 PM
evo8silver
10
May 17, 2005 05:26 PM
